you have to have java/javascript enabled click on one of the headings up top (eg. text & 3d sketch), and the frame on the left should fill with a search form. pop in a keyword and hit enter. if the frame on the left doesnt activate, you probably have java disabled. which means youre probably out of luck, because for some reason microsoft no longer provides downloads of java virtual machine... i reinstalled windows xp, and in order to get into rosity chat i had to spend an hour searching google for a java virtual machine that wasnt linked to microsoft.com. cheers, -gabriel
Attached Link: http://homepage.mac.com/dampeoples/artlinks/stuff.html
That's a very nice site. Thanks for the link. I posted this in the Photoshop forum, but I have started a little log of all the bookmarks i have found. It's crude, but designed foe me, and i thought i would share, hopefully you guys can get some use out of it, I plan to update regularlyHaven't reinstalled and tried it on the new box yet, but Jcleaver mentioned that good'ol Crossroads3D should do the trick. Let me give that a shot first, but thanks much gabriel.
Attached Link: VRML
VRML is Virtual Reality Modeling Language, used (form what I have seen) primarily in creating 3D-/VR-type effects on web sites.Works in Netscape 7.01 and the reason for no more jave update from MS is that Billiy boy got his knickers in a twist when Sun sued them for rigging java so it wouldn't work well or not at all on other browsers than IE so MS played spoiled brat and said they won't even support java anymore in new systems (which has led to another suit)
Why shouldn't speech be free? Very little of it is worth anything.
Attached Link: Princeton 3D Model Search Engine
check it out... you can search thousands of models by keyword, and choose to accompany the search results with 3D previews, then enlarge those into a preview from all sides, etc. cheers, -gabriel
