Tue, Dec 24, 7:44 PM CST
Subject: Please help. Texture problem with Mill girls.
Rynn ( ) posted Mon, 16 December 2002 at 5:52 AM ยท edited Tue, 24 December 2024 at 7:07 AM
The mill girls are supposed to be able to wear vicky's textures, but with several of them I keep having eyelash problems. I checked in the materials window, that everything is set the same as it does on Vicky. But I can't seem to get the eyelashes to look like they should. Can someone help me out here? Thank you, Rynn.
Jaqui ( ) posted Mon, 16 December 2002 at 5:57 AM
is there a transmap assigned for them? they do not look like they are transmapped at all.
Rynn ( ) posted Mon, 16 December 2002 at 6:15 AM
Yes, the transmap is assigned in the same way as it assigns on Vicky.
Rynn ( ) posted Mon, 16 December 2002 at 6:45 AM
Ugh, I think I have found the problem. I had overlooked one thing with the transmap that was not set the same as for Vicky, and that's the transparency min slider. It was set to 0% instead of 100%. It has been a big puzzle for me because several things are not assigned in the proper way when I load these textures on the mill girls. But from now on I should know what settings I need to change. :) Thank you for helping me. :) Rynn.
eirian ( ) posted Mon, 16 December 2002 at 6:51 AM
The Mil Girls use the same UV map as Vicky, so the textures are compatible. But I think there's something different about the mapping. I've noticed Victoria MAT files don't work perfectly on the Kids - there's always a couple of things I have to set manually after applying a MAT that works perfectly with Vicky.
Momcat ( ) posted Mon, 16 December 2002 at 8:49 AM
On both Vicky and the Milkids, there are two materials labeled Eyelashes (one is cased differently I think). Vicky's eyelashes use one set of materials, the MilKids use the other.
Cookienose ( ) posted Mon, 16 December 2002 at 10:54 AM
Out of curiosity, what texture is that? It's gorgeous.
Rynn ( ) posted Mon, 16 December 2002 at 11:15 AM
Yes, it is a gorgeous texture. It's the maia and morgaine texture by Blackhearted, Kiera and Rio. You can find it here in the online store. Thanks to everyone for all the helpfull answers. :) Rynn.
