Sat, Feb 8, 9:40 PM CST
Subject: WIP where to go....
shadowdragonlord ( ) posted Wed, 18 December 2002 at 5:23 PM · edited Sun, 02 February 2025 at 2:14 PM
I've been working on this image for a while, in my downtime at my "real" job, and wanted to get some feedback. Should I just spend more time on post-work, or keep it in Bryce and add stuff? Where should I go with this one... (thanks)
DreamWarrior ( ) posted Wed, 18 December 2002 at 6:21 PM
What a lovely atmosphere! I wish I could be there! I really like the colors, lighting and atmosphere. The only thing I could tell you would be that the water seems a bit like jelly. Wonderful work!
My crafts - My Freebies - My Store - Delightful Arts
ICMgraphics ( ) posted Wed, 18 December 2002 at 6:56 PM
Nice Scene. I agree DW, scaling down the tex size will make a dif.
Roch222 ( ) posted Wed, 18 December 2002 at 7:09 PM
Great Scene - Im Jealous I just cant get a good landscape goin!! I also agree about the water - also maybe lower the water too looks like hes gonna have a flood any minute roch222
bikermouse ( ) posted Wed, 18 December 2002 at 10:03 PM
SDL, I was thinking of the water too - it's like looking down at an otherwise extermely beautiful girl with misshapen legs. the snowflake plugin for photoshop (check my posts over the last few days) seems to work ok if you want to add snow and don't want to bother with a Byrce technique(check tjohns entry on that one theres a tut on bryce snow there). I am otherwise blown away by this image It's very good. - TJ
shadowdragonlord ( ) posted Thu, 19 December 2002 at 3:10 AM
Thanks everyone, I didn't think the water would bug ya, I was critiquing it in totally different areas! I'll fix it, then just post it and save my energy for other projects...
catlin_mc ( ) posted Thu, 19 December 2002 at 4:31 AM
The mountains are terrific, perfect proportion and distance, the smoke looks pretty realistic too. The only problem I have is the water, but you're gonna fix it and that's great. Well done. Catlin
Erlik ( ) posted Thu, 19 December 2002 at 5:19 AM
Well, I do have an objection. :-) Along with water, change the scaling of the trees. They are way too big for the rest. It's not your fault, because Bryce doesn't have a way to make just the trunk taller. Also, lower the number of branches on those that have jumbles instead of crowns. Then, the ground and ground cover should be more or completely yellow, just like the rushes should, too. You have snow on the ridge and then perfectly green rushes. Hmm. Water might benefit from a bit more transparency. Also, I'd lower the islet. I don't think you have such cliff-like ends on ponds or small lakes. Finally, close the door, it's cold outside. :-) Or put a figure or something in front of the house, looking at the sky.
-- erlik
big_hoovie ( ) posted Thu, 19 December 2002 at 5:54 AM
how about some creatures?
BlueArdor ( ) posted Thu, 19 December 2002 at 7:57 AM
Beautiful work. The only thing popped into mind that might be missing is a stack of firewood? Smoke is wonderful.
lsstrout ( ) posted Thu, 19 December 2002 at 12:36 PM
Your sky is just gorgeous. Makes me think of Nothern Lights (not that I've ever seen it except in photos). I think you can get away without creatures, it is winter after all. If you stick some wood out front, and maybe a hatchet as though someone has just been chopping, I think you will give the impression that someone just went inside with an armful for the fire. Lin
cainbrogan ( ) posted Thu, 19 December 2002 at 3:38 PM
Snow here an there would make the ice look a little more realistic. = )
shadowdragonlord ( ) posted Thu, 19 December 2002 at 6:38 PM
Aye, thanks for the input Erlik.. But I'm in the Pacific Northwest, and all our trees are big and jumbled! Cain, I don need to add snow, and maybe mess with the water, it's supposed to be a spring image. Well, that's what I was going for, anyways! We'll see...
