Sun, Feb 9, 4:00 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 1:04 pm)
Subject: v3 uv mapper issues on mac
otaku ( ) posted Sat, 21 December 2002 at 2:15 PM ยท edited Sun, 09 February 2025 at 3:00 PM
Get as far as open v3 object file and trying to import uvs and select the v3 uvs folder created by installer and there is nothing to select. When I open the folder outside of UVmapper the 2 files are there. Using UVmapper Mac 0.2.9 Has any mac user had any luck with the uvs files provided by Daz?
Niki ( ) posted Sat, 21 December 2002 at 2:41 PM
I'm not Mac user, but the UV's work on PC. Well is some errors in it, but mostly work.
mateo_sancarlos ( ) posted Sat, 21 December 2002 at 3:03 PM
You should probably wait for the Daz Character Animation Tool if you want to use V3, since Poser is not really a Mac app anymore.
Spit ( ) posted Sat, 21 December 2002 at 3:13 PM
Since when did Poser 4 stop working on a Mac? Sheesh.
dan whiteside ( ) posted Sat, 21 December 2002 at 3:35 PM
Don't have V3 yet but I wonder if the files need a Type and/or Creator in the resource fork. That's usually what's wrong when files don't show up. UVMapper exports UVS files with Type="TEXT" and Creator = "R*ch" and that wouldn't be included if DAZ just used the PC files. UVS does work on the Mac, btw. Best- Dan
Niki ( ) posted Sat, 21 December 2002 at 3:57 PM
use work to translate from rich file to text file or the oposite, it work I use Visual studio for all that is faster, but befort i'm was using word 6 or 2000 it should work also on a MAC !
otaku ( ) posted Sat, 21 December 2002 at 5:35 PM
not sure exactly what I'm supposed to changed on uvs in my text editor. Can you go into more detail? As for poser not being a mac program anymore that's bogus. A mac version of poser 5 will eventually come out and until then Poser4 is working great for me! As for V3 I've had no problems using her in poser on my mac so far I just have some favorite V2 textures I'd like to use for her.
MarianneR ( ) posted Sat, 21 December 2002 at 5:36 PM
Attached Link: http://www.soft-rabbit.com/
You should use UVS MapDecoder, not UVmapper.
otaku ( ) posted Sat, 21 December 2002 at 7:26 PM
Got it to work! I think Daz may have changed their download since I grabbed a copy. (or I grabbed the wrong file, Although both are .sit files) Download now is only one uvs and it clarifies it's mac.Decided to take a look after getting the bikini at Daz to make sure I was following their directions correctly and noticed that they now mention that the mac download is only 1 uvs file instead of the 2 I had in my folder. Thanks for the support.
