I see, Daz dont use and i use and I get problems and and and , I'm the one to pay for all :( Agggrrrrr.... Any way thanks for the answer i will do this... but now, witch clothes can fit V3 ??? Means there angein a buy for 1000 $ of clothes , now is all for garbage :( No is not seriouse that way to do the tight... we will write to DAZ too beause to sales things that wait is to easy. I'm luky MAXON C4D dont play that game !!!
On my P4/PP loading all face morphs took over 7 minutes the 2nd time - the first time I hadn't realized the "all morph" options required all the 26 !V3... folders to be in place and named just so to load. I keep my Pose folders pruned to under 245, and I had consolidated/renamed/moved the folders the first time - resulted in an unrelenting barrage of error messages until I aborted, re-installed V3 morphs to DAZ's config, and tried again. Like I said, face morphs took just over 7 min to load in P4/ProPak on my Pentium4 2.0Gig, 512Meg, XP.
In Pro Pack injecting all head morphs took 3 minutes, in Poser 5, it was still frozen (non responsive but using 97 to 98% resources) for 30 minutes. In Pro Pack injecting all body morphs took about 3 minutes too, in Poser 5 after half an hour it was still not done loading them, I gave up and shut it down. After loading all head and body morphs in ProPack I have tons of blank dials that the dial cleaner does not remove from the saved pz3 file. There appear to be almost as many blank diala as there are morphs. If I use the dial cleaner, the file grows in size, instead of shrinking.
I just get the DAZ V3, it work on poser 4 and 5. Buit if i try to load on Poser 5 all morphs Expression or others, don't matter ... Poser 5 Lock, Poser 4 work !!! Any one know about it... Also, the clothes of V2 dont fit V3 correctly, here also if any knows about it !!! Also, is two UV's Map, witch one is the good one, try it ! :( both get a problem on the right nipple, a ring around it... Is UV OK, I cant do it in C4d but about poser ???
