Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 6:38 pm)
Here's what I've been using. Occasionally it bombs and I get the hairdo from hell, but it also works quite often. First make sure that the skullcap is not touching the head. Anywhere. Then select the hip and turn on collisions for the hip and press the button to turn them on for all its children. Then select the skullcap and turn collisions OFF and press that button again. In the hair room select the skull cap, select the portion of the hair you want to drape, turn collisions on with the switch beside the display and check the collisions box for the hair. Drape it. Don't pay too much attention to the way it looks WHILE it's draping. That can sometimes be misleading. You can either set them up in advance and drape using the command in the animation menu or drape the sections individually....
Ladies and Gents good evening, I have a question that I am hoping someone can answer .. I have recently been using Dynamic hair with Vicky3 .. no problems at all with V3 (shes lurvly) BUT .. a problem I have with other models does show up with her as well ...
Using dynamic hair with collisions on I get very 'tangled' hair .. using it with collisions off I get verts through her face and shoulders (ouch!)
I am going for long hair over the back (or over one shoulder) kinda psuedo-Sanfran hair from JB .. does anyone have any suggestions what I am doing wrong? the manual is VERY low to the ground on hair help.
If I can get this sorted I'll write a tut on it.
