Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1019202
Check out this thread it might help.Hello, I have a similar problem. I have a Pentium III 800 with 750RAM. When I load all the face morphs, Poser freezes up. I think it is probably my OS ( I have ME). It works if I inject each morph by hand. It is indeed frustrating. Warm Regards, Nancy Deer With Horns (SophiaDeer)
Deer With Horns
Native American Indian Site
Personnaly I think that DAZ should have done some beta testing before selling their product! Since Curious Labs Beta test on Poser 5, it seems that other companies are doing the same!!!!! I don't think it's a matter of cpu, ram, free space or OS: we're too many with too many different configurations, sharing the same problem for supposing that! Probably is it due to Poser 5 itself... But once again DAZ has to sell products that works!!! I sent a message to their technical service 3 or 4 days ago... still no answer for this problem... Wait and see!
Maveris, Many morphs were retired or changed so much that you would not always get similar results using the "same" morphs. A spreadsheet would take alot of time to make. No promises but I can mention it. Olivier, I appreciate that whatever problem you are experience is real. She was beta tested by dozens of people as well as all of us. All using different systems and versions of Poser We'll look into it to see what might be causing the P5 problems some of you seem to have. Your system stats have nothing to do with the injections. Significatly lesser systems have had no problems. It is either a OS or a Poser5 problem. Or a combination of both. We are away till Monday for the holiday. I am sure you will get a response to your email then. Anton Daz3d Platinum Club
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
I agree completely Oliver. My spec: Athlon XP2000, 1.5 Gigs DDR Ram, Win 2K Pro SR2 OS, And when I try to load the V3 !All Body Morphs and !All Head Morphs Injection files Poser 4.03 and Poser 5 Sr2 lock. I can load some of the individual grouped morphs e.g. Breast-Chest etc. but the full enchilada creates a "program not responding message." I used the auto install options in the installer to both my P4 and P5 Runtimes located on Drive C. So Since I am clearly not lacking in Ram or CPU power and my system is tweaked to run at a seriously high optimal for Poser, I can only conclude that there is a bug somewhere in the injection file path system that is evading us at the moment. BTW, I purchased the Base Upgrade, Body and Head morph packs, Poses and Texture packs. Anton I appreciate your personal respose at a time when Daz is short-staffed. It is jaust a hunch, but could it be something with Win 2K Pro and Injection Morphs? STORM Fed-up of being a beta tester
I have exactely the same problem now! Let me explain: before I installed all the files in my download folder and had many difficulties to load any kind of inj poses... the little ones loaded but after a bunch of minutes (10 to 30). I installed the poses into my Poser directory and the "little" inj poses work quicker (1 to 3 minutes). Unfortunately, when I try the "all inj" poses or the "FBM inj" poses: poser seems to take all my cpu working, working, working, but no result at all! Anton, I do appreciate your helping hand but I'm sure of my system! That come from Poser5 and/or the Inj pose files... in my opinion!
btw, have WinME and Poser 4. However, I was a bit low on drive space on C... (down to less than 2 gig) have since changed that situation since then and moved my massive poser installation to a larger partition. Haven't checked to see if it would inject better now, but I can say that the poser freezing problem is real for some of us. It could be a resource management problem on some systems... probably was on mine.
bijouchat I know it is not my system. I have managed to load and use 500MB+ models in Poser on my current system, and use Vicky 2 Cr2's over 120 MB in size (lots of morphs), and everything works fine even with Poser 5. So I think this is a Daz bug. New way of doing things = new bugs. Otherwise I realy like V3 (apart from the lack of polys in her Buttock/Hip area but that can be solved :0) particularly since Daz got rid of the 5+ sided-polys that infected Vicky 2! Regards STORM
It is likely a Poser releated thing assuming people are legitimately allowing for the extended wait of the "all" Injections. It is likely how Poser relacts with the OS. The "All" injectors are trickier because they are scripts that call scripts. There was a problem with P4 "All" injectors but we fixed that one. We'll figure it out I am sure. Adding individually takes about the same time though it involves more clicking. Anton Olivier, Noone is questioning your system. It will be ok, please relax. What is up with all the exclamation points?
-Anton, creator of
since 3-13-07
Poser isn't 'freezing' per se. That's the behavior it exhibits when it can't find something. It looks over and over again and again sometimes forever. I suspect the problem has to do with the libraries and where/which runtime the Pose files were installed. Those who install Vicky 3 to Poser 5 runtime and do the injections from Poser 5 runtime don't seem to have a problem. FWIW
Hi all, I read the post of many people that have problem with load all morph... I just play with my V3 and I found the strange, but true, solution for increase the speed of loading character: - load V3 - load all morph (or individually if you have problem with all) - save the figure (I save in DAZ People with "Vicki3 Full") The cr2 file is about 118MB. My time of loading is now 42 seconds! Hope help you, Mav :)
Hi Mav, Thanks for the advise. I tried it and it works great. Full Victoria3 takes me about 90 seconds to load but that is a lot faster than the 5 minutes it took to load all the morphs before. You're a genius! Warm Regards, Nancy Deer With Horns (SophiaDeer)
Deer With Horns
One thing to make sure of - select Vicky3 body before trying to inject the morphs! I had the main camera selected the first time I tried - Poser locked up. I was still having problems with Poser 5 since I was linked to the Poser 4 runtime. Once I installed Vick3 to the main Poser 5 runtime, everything injects fine (within 3 minutes). Peggy
LVS - Where Learning is Fun!
It's possible have form DAZ a table conversion (like excel sheet) from V2 to V3 dials? For example I don't see: - AbsLine - AbsPak - SuperHeroine ... Where are the corrispondent dials? I think that this help for morphing V3 like V2 character. Thanks in advance, Mav :) P.S. sorry for my poor english
