Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Yes, it works on my Mac. Did you put the obj-file in the right folder, so that the cr2 finds it? If you try to import the obj, via "File:Import:Wavefront obj" does Poser "see" it? I have OSX and do my cr2-editing in BBEdit Lite. It seems to handle the Poser-files well, and often I don't have to use Maconverter, as the filetype stays the same.
Hi Marianne Thanks for your response and I wish it was that easy! The obj is in the correct folder. When I ran it through MacConverter it gave it a PC obj icon-which is the same as the blMilWom_V3.obj that I used in conjunction with the UVS file from Daz. The filepath is correct also. In the Cr2 two instances of the previous geometry name was changed. It seems that I had luck with Word98 before. I will try again with that older version. Maybe I should test changing the filepath and Obj location on a another cr2 to see if it is an issue with the changed Cr2 OR the UVS converted obj.... Thanks again- Eric I could use the V3 to V2 cr2-but I want to keep the v3 geometry! I will have to search for BBEdit Lite- I seem to remember a free version somewhere....
Hi Marianne. Well- I was paying too much attention to creator typing and text formatting. The problem-after that was fixed was a dash instead of an underscore in the Obj file name. Whoops! It works now- although I dont seem able to get either V2 or V3 eye textures to work yet. And the eyebrows-although the V2 eyelash trans work, And of course there are more places to apply textures such as scalp, hip, forearm etc-but they take the V2 body textures just fine! Thanks again-! Eric
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1019255
Look here about eye textures!This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi All. I got V3- a terrific model. I would like to use my V2 textures-with the V3 Cr2. Uvmapper for Mac does not recognize the new UVS format. But the MUCH appreciated MartinC made a UVSdecoder5 utility. So I opened the Mac UVS file from Daz- opened blMilWom_V3.obj and got a new file in the Daz People Geometries directory called blMilWom_V3_V2UVs.obj Great! Then opened a copy of the Cr2 in Word2001 Mac, replaced the two calls for blMilWom_V3 with the new obj name. When I saved as text it appended the Word filetype. I opened ResEdit- changed the filetype to Cr2T and creator to PZ3A. I t became an iconless generic file-not recognized by Poser- OR MacConvertor. I then tried the same replacement on a fresh copy in Texedit_plus which changed the format. Saved as Simple text-with a filetype of PZ3A. Poser did not "see" the cr2. THEN (In texedit) I opened the previous copy that I had replaced the obj name first in Word2001. The format appeared as expected-and I resaved it as Simple text-filetype PZ3A. MacConverter recognized it and changed the Icon to the familiar one-then Poser "saw" the Cr2. When I opened it did not find the converted Obj-although I had run it through MacConverter. Anyone made this work on a Mac yet?? Any help is appreciated!!!! Eric
