Thu, Nov 14, 11:56 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Vicky no works for me... help !!!
olitoth ( ) posted Wed, 01 January 2003 at 10:15 AM · edited Thu, 14 November 2024 at 11:42 PM
Why Vicky no works for me ? I have a computer (800mhz), 368.0 mo Ram. Scan disk : ok, defrag : ok, Tempo : empty... The exe. (for install Vicky 2 on my computer) it's the english version and it create a "library" with the files (hand, poses, character). On the french version of Poser4 it's "bibliotheque" and not "library". No problem, I take the files and rename on my french files (Daz people "character" on Daz people "personnage" etc.) All right, that's works Vicky appear on my "bibliotheque", I working and... bug ! message : - 50 error... What's going on ? Daz no reply to my requests (thanks guys) and that's why I post my message here. I have buy the REAL version of Poser4 and that's works fine for all the characters but not for DAZ. Can you help me ? Where i can upload a french version of Vicky (the exe.). Thanx for your help, i'm sicked.
jobcontrol ( ) posted Wed, 01 January 2003 at 12:50 PM
Hm, I have a German version of P4. "Runtime" is "Runtime" "Libraries" are "Libraries" Only at the stage of the sub-folders to Libraries (characters, props, ect.) are German folder-names. So I'd suggest, you copy the files into a folder structure, like that: - Runtime (use English folder name) -- Libraries (use English folder-name) --- personnage (= files from "characters") --- etc. Maybe you should run "Correct reference" over your runtime. This program is designed to match folder references inside the cr2-files. BTW, your problem with the English filenames and foldernames brought me to buy an English version of Poser 5. Maybe, Poser can successfully work with regionalized folders, but most of the addons you buy from the internet, don't worry about French or German (or anything else) names. Hope I could help you. Willy(from the right side of the rhine ;)
Ajax ( ) posted Wed, 01 January 2003 at 4:04 PM
Check especially where the obj file is located. If you moved it or renamed the folder where it was stored that could be the cause of your problem.
yvesab ( ) posted Wed, 01 January 2003 at 8:58 PM
voila la ronse que j'ai re pour la meme question Thanks for your email, you did the right thing in copying the files to the bibliothues folder. Now run the installer once more to put the files in the Libraries Folder again. (this is the easiest way to do it). In the end it should look like this bibliothues Folder Contents of Character Folder* Contents Pose Folder* (I do not know what the Character and Pose folders are called in French. If you could tell me I would appreciate it very much) Libraries Folder !Daz Folder and everything inside it Pose Folder and everything inside it The Files that you copied into the bibliothues folder are very small, so this should not take up too much extra room on your computer.
olitoth ( ) posted Wed, 01 January 2003 at 9:15 PM
Thanks for your help ! *Will : lol, you are right ! I'm on the dark side of the Rhine :o)) *for Yve, thanks I'll try it anyway (en francais ca donne : merci c'est super cool de ta part. Si je rencontre des problemes, puis-je te contacter par email ? J'ai les boulles d'avoir pay60$ pour un truc qui plante...). Thanks all and happy new year ! Oli
lesbentley ( ) posted Thu, 02 January 2003 at 9:18 AM
It doesnt matter which subfolders the library files go in, as long as the root folders match your version of Poser (camera, character, face, etc, for the English version). The important thing is that the location of the object file blMilWom.obj, matches the two reference lines in the cr2. The cr2 contains TWO lines that reference the obj file, these line must EXACTLY match the location of the obj file in your file structure, this is case sensitive. In the English version (is there any other?) of Victoria 2 these lines will read: figureResFile :Runtime:Geometries:ZygotePeople:blMilWom.obj It technically it doses not matter if you change the reference lines in the cr2 to match your file structure, or change the location of the obj to match the reference lines, but for compatibility with other cr2s that may try to reference the blMilWom.obj its better that you match the file location to the reference lines.
olitoth ( ) posted Thu, 02 January 2003 at 9:37 AM
Thanks Lesbentley, but... kiew, it's very hard ! Anyway, for the "blmilwom.obj", i can't see this file. I have on the geometries (on the french files, why ? I don't know...): blVickiP4.obj and blVickyp4.rsr. Damn, my head killing me... Thanx for your reply. Oli
Ajax ( ) posted Thu, 02 January 2003 at 3:08 PM
Oli, you should have the file blMilWom.obj under RuntimeGeometriesZygotePeople as Les says. blVickiP4.obj is for P4 Vicky and goes in a different folder (RuntimeGeometriesDAZPeople I think)
olitoth ( ) posted Thu, 02 January 2003 at 6:31 PM
Yes it's true : on the geometries : blMilWom.obj. Okay, I copy (not cut) the files (all the files on the DAZ's librairies) on my french "bibliotheque". May be it's not cool to cut 'n paste the files...
Ajax ( ) posted Thu, 02 January 2003 at 6:42 PM
OK, here's my next suggestion. Where you found the blMilWom.obj look for a file called blMilWom.rsr. If you find blMilWom.rsr then delete it and try using the figure in Poser again.
jobcontrol ( ) posted Fri, 03 January 2003 at 4:46 PM
Ohmygod! Olitoth, you're not on the dark side!!! You're only on the left side of the rhine ;-) Willy
olitoth ( ) posted Fri, 03 January 2003 at 6:20 PM
That's works fine now ! Thanks all ! I have a message from Daz and there are sorry for the delay responding (vacations... vacations... ;) For the futur french users, I post my reply to Daz (thanx for yve_Sab for the link to curiousblab) : 1) I have uploaded the french Updaters on http://www.curiouslabs.com/ for Poser 4. 2) Important ! For the french users, your exe. create a "librairies" on the runtime. In the french version, it's "Bibliotheques" and not "librairies". I have "copy 'n past" the files : "hands" "poses" and "caractere". *The files on "Hands" go to : "runtime/biblioteques/mains (mains = hands). *The files on "poses" go to : "runtime/biblioteques/poses *The files on "caracteres" go to : "runtime/bilioteques/personnages. For the file "geometries" it's ok because on french "geormetries" = "geometries" :o) (runtime/geometries/ZygotePeople : blMilWom.obj, blMilWom.rsr). Have a nice day and happy new year ! Olivier.
dreampaint ( ) posted Tue, 07 January 2003 at 6:05 AM
Hello all I'm surprise you talk about victoria 2 cause with my french poser4 version i have any problemes. But with Victoria 3 ouch a lot lot problems. I contact Daz for that and i wait again a correct respons. I imagine germany poser have similar problem and other contry they dont have an englisg version of poser. The real problem it's i buy all face morph and body morph for victoria5 and all line in cr2 search the files in fordels don't exist in french version. Try to change folder in english vetrsion is not ok. There is alot lines to change more than 5000 and really if i must make the work of daz i said NO! So perhaps i must becoming american and buy only american product, but not reallt thanks :) Hope there is soon a real solution to this problem, and hope in the futur, the other products are no similar, or by by Daz. Laurent ps: happy new year form France (the little contry of cheese ;))
yvesab ( ) posted Tue, 07 January 2003 at 6:21 AM
bon je rxplique : Il faut installer V3, les morphs etc en utilisant l'installer standard de DAZ. Il devrait crr un dossier "libraries" en plus du dossier "bibliothues". On COPIE les fichiers du dossier "libraries/pose" et on COLLE ces fichiers dans le dossier "bibliothues/poses" Il ne faut pas toucher au dossier "librairies/!DAZ" si ne marche pas, s'assurer que poser est bien mis jour en version 403 ; et entuellement effacer les RSR corrompus. c'est vrai que tout est un peu agant, mais la faute en est mon avis la "localisation" en franis de poser. Il y a un forum poser en franis:http://www.poser-france.com/
olitoth ( ) posted Tue, 07 January 2003 at 10:27 AM
Laurent, les reponses ont ete donns juste au dessus par Yve et moi meme. Nous avons tous compris que l'exe rajoute un fichier "librairies" dans poser 4 (nom en anglais de notre "bibliothues"). Il faut que tu copie et colle (et non couper et coller) les fichiers de la librairie (en anglais) dans ta bibliotheque mais surtout, que tu fasses une mise a jour de ta version de poser 4 : http://www.curiouslabs.com/ Moi aussi j'avais un gros bug d que je touchau visage (morphing). Maintenant c'est bon.
dreampaint ( ) posted Tue, 07 January 2003 at 10:52 AM
Merci a tout les 2 pour vos rapides ronses. Je vais tenter l'expience. Ceci dit c'est quand memm un sacrbordel. C'est deja asser chiant d'habitude de sans cesse deplacer les fichiers dans les bon repertoires mais la c'est le clou. Laurent
olitoth ( ) posted Tue, 07 January 2003 at 11:15 AM
Je te comprend ! Surtout quand tu payes un bon prix et que ca ne marche pas... j'avais les boulles aussi. Au fait, tu as des textures sur ta vicky ? Moi non, meme pas les cheveux... Bon, essayes la mise a jour pour commencer et "copie-colle" les fichiers manuellement ca devrait marcher. Pour la mise a jour, pas mal de problemes annexes ont ete rl apr le download sur http://www.curiouslabs.com/ Oli.
dreampaint ( ) posted Tue, 07 January 2003 at 11:49 AM
Le rl probleme est que d'habitude malgres l'usine a gaz on s'en sort, mais la il faut 2 fois les memes repertoires. Une en francais et l'autre en anglais pour travailler correctement. D'habitude je deplace simplement les fichier, la non il faut les copier /coller. Pour les textures Oli si tu n'as pas pris le pack de texture tu vas etre un peu dout As tu achetle pack texture high resolution? http://store.daz3d.com/catalog/product.php?pcode=ps_tx307 sinon bha tu vas avoir une vicky asspauvre. Laurent
olitoth ( ) posted Tue, 07 January 2003 at 12:13 PM
Lol, en effet j'ai une vicky vraiment tr tr limit... Merci pour le lien vers Daz, je vais voir si je ne peux pas trouver un gabarie pour faire ma propre texture.
