Fri, Jan 10, 4:02 AM CST
Subject: how the hell do you get skins to go on right?
shadeaux_anne ( ) posted Thu, 02 January 2003 at 3:56 AM ยท edited Fri, 10 January 2025 at 3:49 AM
I've made dozens I just don't know how to get the to go on the right parts...please help me.
SAMS3D ( ) posted Thu, 02 January 2003 at 4:25 AM
Go to the material editor and assign the skin to the right body part...Sharen
Lorraine ( ) posted Thu, 02 January 2003 at 5:39 AM
Well, I am not sure but you also have to apply the right texture template to the right figure so that the maps will apply correctly....
pipermaru819 ( ) posted Thu, 02 January 2003 at 5:55 AM
make sure that you are not useing a p4 map on vicki,in the materials editor the easiest way ive found is to open the head map apply it to "entire figure" by checking the box,then uncheck the box and apply the body map to the skin body,the nipples,fingernails and toenails,then it should turn out right for you. good luck :0)
hankim ( ) posted Thu, 02 January 2003 at 6:00 PM
It's slightly different than described above, if you are using Poser 5, too.
