I found that in space scenes it's much easier to use post processing methods to get realistic space and planets. Bryce doesn't do a very good job in terms of starfields, and as for the planets, unless you know lighting pretty well, you're stuck with unrealistic finishes. Try getting Universe from diardsoftware.com and lunarcell (for planets) for photoshop from flamingpear.com. :) Drac
draculaz, Bryce is fine for creating space scenes. These images at my old site are pretty ancient now (it's about time I did some new stuff), but they show that 'photorealistic' results are possible without pre or post image editing. http://www.pfulford.dircon.co.uk/galleries/space_gal/space_gallery.htm If you just import models, import space backgrounds, and generally avoid using Bryce as much as possible - why use Bryce? ;-)
Very nice pictures PJF. Don't think I've ever seen a Doctor companion in that skimpy of an outfit. :) I agree that Bryce can do planets realistically. In the render above it looks like there are 2 or more light sources. I suggest just using 1 light source and looking for tutorials on doing planets in Bryce, that is unless you are going for the "fantasy" type space scene instead of realism.
ok well here is what i think. get rid of the star feild... go look on the web for pictures of space... preferabbly big ones... the bigger the better. maybe even some taken by hubble. then stick that picture on to a spere... and make the sphere encompass your scene. you will now have a much more realisitic looking (mainly cause the picture is real) starfeild or space background. this is what i am attempting with mine and its working out nicely i think... also... those planets are awfully close together.
I don't think SRAM is using the Bryce star field. Looks like one of the texture presets on a plane, perhaps an infinite one. But I don't see Bryce stars here (they're perfectly round unless perspective distorts them and then they're perfectly oval. I agree with the lighting comments, it does need adjustment. Great start!
Work It Harder. Make It Better. Do It Faster, Makes Us stronger. More than ever, hour after hour. Our work is never over. - Daft Punk
