Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 2:04 am)
p4 or p5.... during the render? or it is froze when the render completes.... System info... how much ram, processor, operating system, etc etc could be many things
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
FACE camera may be the problem. Even without a render if I switch to FACE camera the head can make only one move and freezes. This happens with Vic2 and the P4 folks. Running Poser 4.03, Win2K, gig of RAM, RAID 0 and no other proggies running. I can switch to MAIN camera and the body will move...if I then switch back to FACE camera the character (male or female) freezes.
Poser is so strange sometimes. I use P4 and tried all these thing and it is ok. Very odd indeed. See if it continues to happen. And try to repeat the same crash over and over to see if it isn't just a Poser fluke. That is when you have free time. Sometimes very specific sequences of events make poser freak out. On my Poser it is when I invert the x tran settings for the mag base boefore moving the zone. Go figure. Poser doesn't use hardware accelleration so I am not sure about the video card. Odd. If it still happens over and over, you are unable to find what is wrong, contact us and we'll take her back. Anton anton@daz3d.com
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
I was under the impression that denden wasn't referring to an actual "crash". When I've got a couple of different highly detailed models in a scene (i.e. mildragon + vicky), sometimes morph dials just stop working. Nothing actually freezes or locks up... just stops working... the models can still be moved in their x,y,z coordinates, the scene can still be rendered, and the program can still be closed normally... but all 'posing' operations fail to function. PPP, 2.26Ghz P4, only 256Mb RAM though. (santa didn't come through for me). I figured my amount of RAM might be my problem
The injectors do need that folder to be present. Without it the scripts cannot run. Starting to understand the proplem people are having in P5 now. They didn't directly install her? They are accessing the P4 runtime?
-Anton, creator of
since 3-13-07
It seems to be that way Anton, if you use a linked runtime and the !DAZ folder is in that linked runtime, it can take an age to load the all morph injectors, or any of them. Once I moved the !DAZ folder to my P5 runtime, problem solved. I use my linked runtime, and the inj/rem folders are in my linked runtime and the !DAZ folder is in P5 runtime, and I have no problems at all now.
After I change Vic3's eyes to green and do a render she freezes. Nothing will move. I hope there's an easy answer. Thanks. PS I have the Body, Head and the extra maps for V3.
