Thu, Nov 28, 7:43 AM CST
Subject: Request for Help with Sudden Memory Problem
Rhiannon ( ) posted Sun, 05 January 2003 at 1:03 PM ยท edited Thu, 28 November 2024 at 7:40 AM
For whatever reason, all of a sudden Poser gives me an "insufficient memory to render at this resolution" error message when I attempt to render an image in a new window at 300 dpi. This has never happened to me before ... it started last night when I attempted to render an image including Victoria with some clothing, the RK Dungeon, and the Mil Dragon. I thought perhaps it was simply the quantity of objects and high resolution textures in this image that was the problem, but now I can't even render a simple Victoria figure with no mats at all at 300 dpi. The only other thing I did last night was download a few things small things from DAZ. I constantly try to keep a handle on the files within Runtime ... I'm at a loss. I have a Pentium 4 2G Processor, 1G of RD Ram, 80G Hard Drive with 40G free. Running XP ... have my paging file size maxed out at 3072, and have never had any problems even rendering a Bryce file at the same time I'm rendering a Poser file, with several other programs running as well. Does anyone have any ideas to try? I surely would appreciate it, because I'm going to pull every red hair outta' my head if I can't correct this bloody problem!!!!!
SamTherapy ( ) posted Sun, 05 January 2003 at 1:06 PM
Try deleting all the temporary files from your web cache.
Rhiannon ( ) posted Sun, 05 January 2003 at 1:19 PM
Sam, you are my hero now and I worship your genius mind! :-) Rhi ... feeling sheepish and stupid for not trying this first! :-)
SamTherapy ( ) posted Sun, 05 January 2003 at 1:40 PM
bows At your service, Rhiannon. :)
Archangel_Gabriel ( ) posted Sun, 05 January 2003 at 2:06 PM
There's also a FAQ in the support section at Curious Labs on this topic/problem. FYI D.
rogergordian ( ) posted Sun, 05 January 2003 at 2:08 PM
Two things have helped me with this problem in the past: 1.) I moved Poser to a different hard drive than Windows. That helped the most. 2.) The problem still creeps up once and awhile. The solution then is to defrag the hard drive. I recommend frequent defragging.
queri ( ) posted Sun, 05 January 2003 at 3:55 PM
Quoted from CL FAQ's it works. Poser 4 Poser can't render high resolution images. Error appears "Insufficient disk space to render" After some intense investigation we believe we have a work around. It turns out that Windows NT 4, 2000 and Windows XP must be using some space for the pagefile.sys file on the same partition that Poser is installed, to render large images. The pagefile.sys is the virtual memory or temp space for Windows. An approximate minimum would 10 MB. This amount might have to be increased for more complex scenes and animations. The maximum should be 10 MB or greater. To modify the Virtual Memory: Windows NT 4 = Right Click my computer. Click the performance tab. Click change. Click the drive Poser is installed on. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Windows 2000 = Right click My computer. Select the Advanced tab. Click Performance option. Click Change. Select the drive Poser is installed on. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Windows XP = Click Start. Right Click My Computer in the menu. Select Properties. Select the Advanced tab. Click Settings, next to Performance. Select the advanced tab. Click Change. Select the drive Poser is installed on. Click the Custom size button. Enter 10 in the Initial size field. Enter 10 or more in the maximum size field. Click set. Click OK. Click OK. Click OK. You may have to restart the System. Poser will now be able to render up to its maximum size of 4090 pixels x 4090 pixels @ any resolution
rogergordian ( ) posted Mon, 06 January 2003 at 6:45 AM
I never mess with the Virtual Memory. However, my method definitely works.
dpoosch ( ) posted Mon, 06 January 2003 at 6:57 AM
Is it possible to move poser to another drive without uninstalling it and re installing on the new drive. I have had similiar problems even though I defrag frequently. In other words can I just grap the curious labs folder to a different drive?
queri ( ) posted Mon, 06 January 2003 at 8:46 PM
I've done so several times. The only time you have to reinstall is if you move that drive to another computer. You do need that CL memory fix I quoted though or system gets confused and you are stuck with rendering in the display window. Whether you defrag or not. My worst probs came right after a defrag and cleanup of temp files. Haven't done it with Poser5. Now that the security's off it should be possible. But I don't know for sure. Emily
