Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
If you save the image as a .BMP you can just right click and rename the extension to .BUM But that only works for .BMP (bitmap) file Anton
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
1.) Before you use Vicky 3, run Poser, and load a prop. I use the ball. 2.) Go into Render, Materials, and Bump Maps. Find the bump map and load it. 3.) Say Yes when Poser asks if you want to convert the bump map. When Poser is done, select the next bump map to be converted, till you're done. 4.) When you're all done, click OK. Then get rid of the prop. 5.) You're ready now.
Do you guys know how to convert .jpeg to .bum? I seem to be having trouble getting V3 to look proper.
