Thu, Dec 12, 11:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: V3 problems, ARGH!!!!!!
Alastor_God ( ) posted Tue, 07 January 2003 at 7:21 PM · edited Wed, 04 December 2024 at 3:55 PM
ARGH So many problems. Always!!!! Anyway, here is the problem. Whenever I try to put V3 in the scene an error shows up saying that it can not find a specific Runtime/Geometries folder. I tried installing her again but it did not work. Might it be, because I am using P4.03? My friend uses same Poser and it works for him. Why doesn't it work for me? ARGH
Simderella ( ) posted Tue, 07 January 2003 at 7:27 PM
have you moved your main poser folder, or renamed a file? I also have Poser 4 and she works perfectly for me... wish i could help more. I suspect someone here will be able to help u more... -=SimderZ=-
Alastor_God ( ) posted Tue, 07 January 2003 at 7:32 PM
I did not move/rename a thing. Oh and I forgot to mention that there are two missing folder messages and than it says that Poser is out of memory and all my work is deleted. ARGH once more!!!!!!!!
Desdemmonna ( ) posted Tue, 07 January 2003 at 7:34 PM
That's been happening to me a lot lately too...are you using the full base or the upgrade base...I'm using the upgrade myself. Going to slap in another ram chip (256 right now) and see if that will help. Dunno what to tell ya :(
procchi ( ) posted Tue, 07 January 2003 at 7:46 PM
If the .obj is in the right place, try deleting the .rsr file from the same directory - that's a compiled version of the .obj, and may have gotten corrupted, causing your problem The reason there are two messages is that the .obj is referenced TWICE in the .cr2 file
pendarian ( ) posted Tue, 07 January 2003 at 11:39 PM
Yes, what procchi said, delete the rsr file in your geometries folder, and try to bring her into Poser again. That should fix the problem. Pendy
Poppi ( ) posted Wed, 08 January 2003 at 6:42 AM
yup...that happened to me. i deleted the rsr in the geometires folder and it worked like a charm.
PheonixRising ( ) posted Wed, 08 January 2003 at 12:08 PM
Don't take this the wrong way, but did you buy her? If you borrowed her then your firend likely didn't give you all the folders you needed. Other than that there is no reason you would be missing folders.
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
