Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 2:40 pm)
have you moved your main poser folder, or renamed a file? I also have Poser 4 and she works perfectly for me... wish i could help more. I suspect someone here will be able to help u more... -=SimderZ=-
Don't take this the wrong way, but did you buy her? If you borrowed her then your firend likely didn't give you all the folders you needed. Other than that there is no reason you would be missing folders.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
ARGH So many problems. Always!!!! Anyway, here is the problem. Whenever I try to put V3 in the scene an error shows up saying that it can not find a specific Runtime/Geometries folder. I tried installing her again but it did not work. Might it be, because I am using P4.03? My friend uses same Poser and it works for him. Why doesn't it work for me? ARGH
