Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
I didn't understand the comment, "Yeah, typicaly Velvia, try next time a later time of the day so the sky is more blue." Maybe Velvia somehow handles an ACTUAL blue sky with difficulty? Maybe a UV sensitivity? Perhaps if there is a blue sky, the colors intensify near sunset? Maybe the commenter could explain. But on one of these completely overcast days, the clouds aren't magically going away. And if it was a bright, sunny, blue sky, you wouldn't be getting that wonderful softness in the trees. [Personally, I'd rather photograph anything on a cloudy day, than fight with harsh shadows.] I believe you are correct, if the scene is bright the only ways I know to use a long shutter speed are; a) Stop the lens way down, (view cameras used to have f64); b) Use a slower film (and you've already pointed out it can't get much slower); c) Some sort of neutral density filter, (they come in various flavors, 1Stop, 2Stops, 3Stops).
If you use a polariser on a bright day, you will lose about 1 1/2 to 2 stops of light. So using Velvia at F16-F22 and a polariser should give you exposures of over 1 sec good enough for the smoothness of water your looking for. Plus practise at diffent times of day at the same place and then conpair results. Great photo BTW
Eggiwegs! I would like... to smash them!
They also have "Variable" ND filters. These are pretty expensive, and I've always been cautious of them. I think they are basically two polarizing filters, that you can cross at different angles. Mess up certain auto-focus? Mess up your nice reflections? ND filters are cheap, and there really is no need to buy several different values. Pick something like a 2Stop, or 3Stop... [On your digi, how far can you turn the "ISO" down? 25?]
Hmmm...I'm not a landscape person, but I recently read a few articles on landscapes and reflections. Have you tried shooting early in the morning or late afternoon? That way, you get the blue skies but the sun isn't high enough to be overpowering. And because it's low you can actually shoot in the direction of the sun without blowing out your scene. For the water reflections, you'd also want to pick a time when the wind was as still as possible. A polarizer would be good to drop you down 1-1.5 stops as well as giving you more saturation in the blue sky. You might also think of using a split neutral density filter if shooing then (so that the sky doesn't overexpose). You can get a nice Cokin filter holder for under $20 and most of the Cokin filters range from $15-30 each (cheaper when you're not paying for the metal rings and stuff like the Hoyas, B+Ws, Tiffens, etc). -=>Donald
Thank you all....Wolfsnap's thoughts point for point are exactly where I was trying to go with this...Dear Wolfsnap you are so thorough in your replies! I have read in many, many books that shooting waterfalls should not be done on sunny days, regardless of the time of day, and for the reasons Wolfsnap stated above. Which is why I started wondering if I was stupid and there was something that I missed somewhere along the line... I'm not bashing anyone's comments, quite frankly I looked at this as a learning opportunity for myself and for everyone here which is why I posted the image and comments on the forum. @ Donald....I have literally a pile of Cokin filters...Circular Polarizer and ND filters included in that. The problem with polarizers on an image such as this is that it would remove the beautiful colored reflections from the water...not an option if that is what you are trying to show. BTW I like the color enhancing Marshall and the crop is very effective, why didn't I think of that? LOL! @Misha...my digital goes from ISO 100 to 800. :~(
I am, therefore I create.......
--- michelleamarante.com
Michelle - With a circular polarizer, you should be able to adjust it so that it does not remove the reflections. My experience with CPs is that they only work for significant reflection removal from water/windows when used in a very specific way (specific range of angles to surface with filter rotated to a second specific angle to match the polarized light coming off surface). I've read articles by landscape photographers who are both for and against the use of the CP for landscapes. I know Moose Peterson uses them alot (his famous CP + 81A warming filter combination), but I don't know about his water shots. The ones who use it say that if used correctly it can remove the blue tint/haze on the land/water (as well as darkening your skies and acting like a ND filter) without removing water reflections. From my experience, I'd agree with that, but it's something you'd have to set up correctly for it to work properly. Then again, most things with photography are like that. :) However, since you already have ND filters and a Cokin setup, I'd experiment with those and forget about fiddling with the CP to get it set up right. A partly cloudy day, early morning/late afternoon and a ND filter should allow you to hold down the contrast in a shot like this so you get good shadow detail without blowing your highlights out. -=>Donald
Well, I'll have to give it a try sometime Don... :~) if I can get myself to wake up in time for a sunrise or not be too busy to grab a sunset sky.... I'll be honest and say I still seriously have my doubts about it working "well", not that it won't work at all, just not "well".....and for reasons that have already been stated but I'm willing to experiment with it. With all the photo magazines I can't believe I've never read an article on this before. Unless my memory is shutting down on me... Do you have any specific articles on this subject?
I know exactly what you mean. I have been trying to get up early on my days off for the last month so I can photograph the seals that hang around the Edmonds fishing pier here. See any seal pics for me yet? hehehe. There has to be a technique for this. There are way too many great shots like the one you are taking with beautiful blue skies, fluffy white clouds and fantastic reflections. Doh! Reflections...I completely forgot about it. I religiously read the British magazing Photography Monthly. The Dec 2002 issue has an article on taking pictures with reflections. It wasn't so much a technical article, but sets up some good tips. The magazine is about $7 here in the US, but well worth it. If you can't find it, let me know and I'll see if I can type it up (it's only 1 page long). -=>Donald
Point 5: ND filters would have only stretched your shutter speed out (or forced you to stop down more) - they would not have altered the scene (with the exception of blurring the water a bit more - which I don't think it needs - or give you more depth-of-field, whicj I don't think it needs) Absolutely correct. Only thing an ND filter would do would allow the longer shutter speed on a bright sunny day. This would allow the water motion blur. But would not fix: >Point 4: IF you shot this image on a clear day (with a blue sky), the contrast range of the scene would have exceeded the range of the film (either the shadows would have blocked up or the highlights would have washed out). An ND filter would just shift everything down, not change the dynamic range. Could THIS have been the point of the original commenter? Perhaps (s)he thought the sky was blue, but washed out? [There are tricks to play by making two exposures, and combining in photoshop...] Keep shooting on these nice evenly-lighted days, 'Chelle.
Point 5: ND filters would have only stretched your shutter speed out (or forced you to stop down more) - they would not have altered the scene (with the exception of blurring the water a bit more - which I don't think it needs - or give you more depth-of-field, which I don't think it needs) I didn't state that correctly - an ND filter would stretch your shutter speed out - or force you to OPEN UP the aperture - which is going to give you LESS depth-of-field (I said stop down giving more DOF- which is wrong) Sorry for the mix-up (but I was having quite a few that night :) ) The point is that the ONLY thing ND filters do is allow you to vary your shutter speed / aperture combination (either letting you shoot with a slower shutter speed at any given aperture, or shooting at a larger aperture for less depth of field at any given shutter speed. ND filters DO NOT saturate or darken any portion of the image (unless you don't make the exposure adjustment when using them - but then what you have is an underexposed image.) As to what Misha stated about "Perhaps (s)he thought the sky was blue, but washed out?" - could be (but I doubt it).
