If your talking about the clipping bracket in the terrain/lattice editor just click and drag the bottom of the bracket itself (not the gradient bar) up to clip at the bottom, click and drag the top of the bracket to clip at the top of your terrain. If you don't see the bracket, one of the icons at the top of the center image (view from the top) of the terrain will turn it on. I could illustrate this better with a screenshot, but I'm not home now. Maybe someone else will do that if this explanation isn't enough. Hope this helps.
DOH !! Thank you tjohn. I have been driven absolutely bonkers by gabbing the gradient bar for clipping and not getting any results. Every Tutorial I have ever tried where I have had to use the clipping bracket never worked (I thought I had a faulty version of B5)none of them have ever mentioned to grab the bracket itself and not the gradient bar. For some reason it never occured to me to grab the bracket. What's that saying "Cant see the forest for the trees" This is why I love this forum so much.
Also if you haven't figured it out by now, it helps to use this with terrains set to "render as solid". That little pull-down arrow below the terrain editor window will have the setting there. Just in case you didn't know. Otherwise your stuff will be hollow (sometimes it might be intentional though.) Just my $0.02.
Yeah, clipping at the top=instant volano if you leave it hollow. Only discovered this feature by accident myself long ago (was this feature in Bryce3D? Started with that version), I think my mouse slipped when I clicked accidently and pulled the clipping bracket down at the top. For a second I thought I broke something, then a little light came on in my head. :^) Has a Bryce manual been really readable? I mean, no offence, but the manuals have been a little hard to read straight through. Mostly I would think of something I wanted to try, try to think of what it might be called, then see if I could find it in the index. LOL
Can someone please give me a quick run down on how to use the clipping bracket in Bryce 5. Thanks
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
