Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 17 1:08 pm)
You have two choices: you can either use a prop like the ones available at Ghastley's site (http://209.92.41.204/Poser) or you can paint it on the texture map directly and then morph the jawline to give the illusion of the raised surface. I recommend the latter, only because it looks more realistic. If it's for Mike, the Fantasy Beard from Daz is wonderful, but a real resource hog.
I grew this on the P4 Male with Poser 5. It looks a bit better than my first attempt.
P5 Beard Test #2 (MPEG format, 345KB)
I'd have to agree, though, that in most cases a transmapped beard prop or a morph/texture combo will suffice.
Anton's Fantasy Beard (MPEG format, 335KB)
the title says it all. any help would be greatly appreciated.
