The first problem is easy to solve, this is a general problem with the german poser (the developers who did such a nonsense of translating the names of library folders should be #&!%...): Don't rename "Posen", just make a new folder named "Pose" and copy all of the V3 morph injectors into this folder. If you select then something under "Posen/V3" the morph injector will be taken from "Pose". You can also edit the files for correct reference and only use your "Posen" folder but I think it's much easier to spend this additional 20 megabytes...
I'll point this to Rob. Sorry for any inconvenience. German huh? ekk. Please tell me there isn't a Japanese version floating around somewhere.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Der er altsikke nogen speciel version af Poser pDansk. Desvre. alts ;o)
I had P4 and PPP - German version. Now I have P5-English version. Can you figure why? ;-) I had enough of moving files from the English folders to my German ones whenever I d/led another zip-file and unpacked. With the new features of V3 (esp. morph injection) this is simply impossible (see above). Willy
Attached Link: http://arcana.daz3d.com/daztech/index.php?id=23
Here is something that might help for now and in the future as well. Pay close attention to the part about V3 at the bottom. I would like to have it in German and French too. If someone would like to Translate it now I can put it up, otherwise I will ask Reba and Micah to do it on Monday. Thanks Ryan tech@daz3d.comThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi there --
I installed the new Victoria with head and body morphs on my Mac (german MacOS) and I am running in serious troubles. The folder hierarchy with my german Poser ProPack is like following:
Poser4/Runtime/libraries/Posen
The Victoria Morph Injectors expect a different name of the last folder: "Pose" instead of "Posen". So none of the Morph injections work. I cannot rename "Posen" to "Pose" because in this case Poser itself won't be able to see the Pose folder at all.
Even more worst: My Poser gui is cluttered with empty parmeter dials, named "-"
The DAZ-tool "dialcleaner" is Windows only, the Python-Script, posted by ockham < http://www.renderosity.com/messages.ez?Form.ShowMessage=1031822> doesn't work on my machine. Weird situation!
And to make it a little more worse: The folks at Curious Labs didn't respond to my mails... :-/
So anyone here has a tip?
