OK, we have a confusing question an answer: "Will the Correct Reference program help me here, or does it have problems working in P5 (or in W2K)?" "correctreference doesn't work within p5." I don't know of any Poser-related utilities that actually are called or used directly from "within" Poser. All this moving of Runtime folders gets confusing. All my Poser 5 in a totally separate Runtime folder, outside of Poser 5 itself. I used CorrectReference on every single item installed in poser 4 & Poser 5. That worked the best for me.
Thank you all for the help. Sounds like Correct Reference could cure my load-time blues. Now, can someone remind this fuzzy old mind of the link to get Correct Reference?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
I originally copied my old P4 Runtime files directly into my first installation of P5 (instead of linking the two) and utilized P5's flexable library structure to reorganize things. Today, I uninstalled P5 totally and renistalled it with the CL Content updater and the latest SR patch, then remerged my backups of the old P5 files being careful not to overwrite any of the newly updated P5 content fixes. Also, whereas my old P5 was installed directly in the root C drive, I reinstalled the updated version to the default "C:CuriousLabsPoser5" directory. Now it seems that it takes P5 forever to find and load textures to most any of the items that I previously had modified and saved in my old P5 (and some never load at all, just freeze up P5). Two questions: Is the patched version of P5 less efficient in finding and loading textures than the original version, or could it be because my updated P5 is looking first for the textures in the old P5 directory structure? Will the Correct Reference program help me here, or does it have problems working in P5 (or in W2K)?
