Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 22 9:03 am)
Oh yes! This is really nice :o)
Okay, well, when you turn the floors off (or make invisible), or turn the walls off you will see the basement, the first floor and the secondfloor, you will see the differences in the rooms because you can see the outline of the basemolding. You can turn each floor off (or make invisible also), so if you want to put someone in the basement and get a good camera shot, you would first make the basement floor visable, place your person, make the walls visible again after you place your camera, I would use the dolly camera and use your dials to manipulate position in Poser to do this. Also it depends on what software you are using, but in any event here are the following groups that can be shut off or made invisible, this is a guess cause I don't have my list in front of me....but it is in the readme file, but to my best recolection: Groups: Brick BasementFloor BasementWalls BasementCeiling Doors A thru T FirstFloor FirstFloorWalls FirstFloorCeiling SecondFloor SecondFloorWalls Roof All of these you can make invisible or turn off (depending on the software you are using), place your person or object or camera, turn them back on or not....up to you and your project that you need. Sharen Does this help?
For instance, you want to put a kitchen and a person in a specific room, you make sure that the floor is turned on, place your person and or other objects, get your camera shot ready, then make the walls visible again and there you go.....don't try to manipulate through the walls with the camera, that is timely and can be aggrevating. You really have to have the ability to make walls invisiable during the time of placement of objects or people, that is why you can make our walls invisible. Sharen
This house is amazing and strangley looks really familiar to me. WINK! :)
I'll be releasing an alternate texture pack with about 50 cameras and some lights sets for this house this week or next sometime.
You guys really knocked this on out of the park!
Regards,
Brent
If you want to up your content game, get schooled to be a pro with Sixus1 Mentoring today!
I've already got an expansion pack underway that will add about 50 or so preset camera poses, lighting setups for all rooms and at least 1 complete new texture map. It should make navigating through the somewhat large house alot easier. Poser's camera is sometimes tough when turning corners, etc. this will smooth a lot of that out and really making scene setup effortless. I also plan to include a basic set of furniture.
You have been busy, I should tell everyone that the verticies have not been split for this house due to trying to keep the size smaller, but, you can split the verticies in parts, example you can take this house into UV mapper and delete parts that you don't want that would make the model smaller, if you don't want the iron work that is around the house on the porch you can delete them from the model, save the model and the model will be considerately smaller and then you can split the vertices and all things will be straight and no rounded edges. Or I can do it per your request. This is only for use in Poser, all other applications will show everything nice and straight. The pictures above have been rendered in Vue and Bryce. Sharen
What I mean is it can be used in all applications, but the above pictures that Greybro posted those have been rendered in Poser, the pictures I rendered has been done in Vue and Bryce. So as you can see the rounding has taken effect by not splitting the verticies for use in Poser. Hope I am making myself clear. Sharen
I should have pointed that out. My bad Sharen. Hey, Hendrik is really excited about your project to model his house. He's talkedabout it all day. You can put me down for a copy of that one as well. Regards, Brent
Attached Link: http://www.sams3d.com
Well it is finally done....this is the Hillside House...It has 7 custom texture maps, 20 doors all poseable, 3 floors, Basement, first floor and second floor. Every room textured, mat files included Poser ready, each floor has easy access so you can set cameras etc. Hope you like it. Sharen
