Sat, Feb 1, 5:05 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Second cry for help.. technical assist on OBJ files not readable
Ikyoto ( ) posted Sat, 29 April 2000 at 8:51 AM ยท edited Mon, 20 January 2025 at 4:02 PM
With the "Millie" change from Jaeger and now with the tail I re-loaded, Poser gives me "Cannot open" when it looks for the OBJ file. The name is EXACTLY the same - I can set the path any way needed and the spelling and case are perfect. It then goes right into the memory leak - "not enough memory" and tells me to allocate more to Poser. I have 256MB on this machine and 500+ on the other! Why are these OBJ files giving me a headache?
ScottA ( ) posted Sat, 29 April 2000 at 10:15 AM
If you can import the .obj files as props. Then the problem is almost certainly in the .cr2 file. Are you comfortable with editing and debugging .CR2 files? ScottA
Traveler ( ) posted Sat, 29 April 2000 at 10:58 AM
Delete the .rsr file that goes with the .obj Poser mangles these sometimes and it always gives that error.
Ikyoto ( ) posted Sat, 29 April 2000 at 11:24 AM
editing and debugging CR2's is not a prob. What do you have in mind. And I will try killing the obj rsr files now. -------- Damn! It looks like it was the rsr in teh geometries folders. I'll make note of that from now on. Thanks for the tip.
Traveler ( ) posted Sat, 29 April 2000 at 11:28 AM
No problem. When poser has to build a .rsr from a .obj file, sometimes it mangles the .rsr
ScottA ( ) posted Sat, 29 April 2000 at 11:54 AM
Wow. I've never run into this problem before. How often does this happen to you guys? ScottA
Ikyoto ( ) posted Sat, 29 April 2000 at 12:15 PM
Only these two items. They were both dl'd - Jaeger's adjustment to the mesh for Victoria and the tail from SphereBot. Unless it really calls for it I'll just dump any rsrs assotiated with obj's.
Traveler ( ) posted Sat, 29 April 2000 at 1:21 PM
I had a problem once with something I downloaded, and have helped a few other people who emailed me. Its always the .rsr. once its deleted everything works :)
3DSprite ( ) posted Sat, 29 April 2000 at 3:55 PM
Actually, as I have just recently experienced, THIS kind of thing happens an awful LOT!!! FUN with Poser ;-)
Nance ( ) posted Sat, 29 April 2000 at 4:51 PM
I've had it happen, not infequently, but especially when I'm multitasking a bunch of other apps when the .rsr is building.
bloodsong ( ) posted Sat, 29 April 2000 at 6:29 PM
yep; the 'cant find obj file' 'out of memory!' schtick means 'your rsr is corrupt.' :)
