I asked this same question some time ago and the answer was no. I haven't been able yet to contradict that advice. Sorry. Let me know if you find a way though. One thing which does help, if you are not sure of textures and think you might change later, is to select all the mesh you want and give them a color group. You can later select that same color and get all the same seletion for texture changes.
Yeah, it would be nice if you could bring up that list and use the shift and/or control as you normally would (like in explorer) to select all the files you wanted in one fell swoop.
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
You can control-shift select objects from the image itself. Dunno if that helps any, but you probably know that already. Sometimes these things just take a while.
You can't do it all at once but it can be done. Once you have your mesh list up hold down the shift key and select the first mesh you want, the list will disappear, bring it up again and just repeat the step until you have selected all the meshes you want. Alternatively you can first click "select all meshes" and then subtract from the list using the same method. This is definately a slow and tedious process if you want to select/de-select a lot a meshes, but it is an option.
If you have to select lot's of objects and they are overlapped by only a few that you don't need you can just drag-select the whole bunch and deselect the few that you don't need. It's easier to select 105 meshes in one swoop and then CTRL/SHIFT/Click 10 of them that you don't want selected then selecting 95 meshes one by one.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
For overlapping objects, you could also try the shift_select - that can have some interesting effects on what objects are selected.
Digital
WasteLanD
Flak, holding the shift key while clicking the mouse works selects everyting in a line from your mouse through the plane. In otherwords, everything that would be overlapped at that cursor point. If you only get one mesh you don't want, like the ground plane, its easy enough to keep holding the shift key and move the mouse to where there is only the ground plane and click again. That ditches it from the selection. Roch, yeah, regrouping blows the color thing. This is genuinely a pain. Is it worth running through Grouper or is it bryce only?
Roch222
