Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 13 4:12 am)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
Mind Over Matter
"If you don't mind, then it don't matter."
Moe; what the heck is this vertice splitting procedure anyway? I volunteered to make a movie projector for a guy in the Poser forum, and did not a bad job of it considering I'm just getting my LW legs. Rendered some stills of it and thought I was quite something. Loaded it into Poser and it was a chocolate mess, even after export .obj and LW5. I went back into LW, cut each and every polygon out and put it into it's own layer (to make sure I hadn't missed any) and pasted them back into a single layer without merging points. Chocolate mess again. What the heck is the proper way to do this? (Don't even think about answering until you're finished with your race) Thanks alot.
Sweet spears, Moe:) Now all you need to make is the dragon barding and saddle for the armoured rider ;)
Digital
WasteLanD
Hiya krimpr, I'm not an expert on modeling for Poser but in my limited experience I have noticed two things... (a) Poser has a default smoothing angle of 100 degrees, and (b) Poser doesn't like n-gons. The Poser render engine will smooth anything and everything, it is very good at that. Which doesn't work very well if you want a sharp edge or a hard corner. My first attempts looked like blimps modeled by the Pillsbury doughboy, with surface normals flipped all over the place. I always model with quads and tris for Poser, no n-gons. I try to avoid non-planar/degenerate surfaces but that's not a priority anymore. If a surface needs to remain smooth I keep the points of those adjacent polygons all merged and shared. If they need to have a sharp edge, I do exactly what you described - cut them and paste them back into the same layer without merging points. To keep track of what is happening and avoid confusion while modeling in LW, I put the smoothing angle of all my surfaces to 100 degrees. That way I can easily see what should get merged and which ones get split. Hope that helps. :o) Cheers! - M
Mind Over Matter
Yes, krimpr... sorry, I should have been more specific... an "n-gon" is a polygon with greater than four point. :o) Some folks at DAZ have a workaround that allows you to model without splitting vertices and still retain a sharp edge, but I hear that it creates a lot more geometry. I'm not sure of this technique (never tried it, dunno how), but I like to keep my polys as low as possible. It kinda makes sense to save on polys for props so that you can go nuts on your main focus - your character. Cheers! - M
Mind Over Matter
Hiya markdc, What are the advantages of the tiny chamfer/bevel aside from saving a bit of time? I know that it will definitely generate more geometry... albeit insignificant considering the rest of the scene may have over a million polygons. Just exploring other ways of "skinning the cat". :o) - M
Mind Over Matter
![file_42059.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_42059.jpg)
Posted on request. Here's a WIP of a weapon I am working on as part of an exercise in modeling (LW), mapping (uvmapper), texturing (Photoshop). Trying to keep the polygon counts under 2k polys per weapon. And complete modeling and conversion (for Poser) in under an hour. Lemme know what you think. :o)Mind Over Matter
