Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Trust me when I say that if I can do it, anyone can.
You have to be careful the omnilight doesn't get accidently blocked (check where the red center spot is). But I think it will work with some experimentation.
CatDabbler: beautiful pic! The omnilight problems in all cases seemto be that the ERC breaks. In mine, it simply does nothing. Reports indicate that in LesBentley's the ERC either works or goes dead. Not sure which differences in settings cause this. The DLK props that have an omnilight attached to them already seem to have no problems rendering if the settings are left as-is. The problems seem to come in when the settings in the BODY are modified. I am pretty sure this is a result of the P5 crosstalk solution somehow spazzing out because it doesn't know how to handle the idea of someone hacking in a light, rather than an actor, as a body part.
A tip : connect the colortextures for all mats using fire or similar ,additional to the ambient color and set the value to 1.Or to the alternate diffuse. And use lesbentleys omnilights from freestuff.
