Forum Moderators: Staff
The second link is following the gravity box. Then I have a three link buffer zone which is not following anything. The remaining links gradually increase in "point at" value from .025 to .5. Works pretty well, although the gravity box requires a tiny bit of manual tweaking.
Err.... Tutorial? Yess.... I always feared that this day would come.... I had hoped to maybe share the file and let it speak for itself. Umm. I will see what I can cook up, however.... And, umm. No EMC involved. Very simple use of the "point at" command. It just takes a little bit of time and (in my case) a calculator to set it up. :) Thanks for the comments. If anyone wants to try a copy, e-mail me or message me or something.
Thanks, lesbentley. I haven't heard anything from Scoopey, whose chain file is used, so I can't post this anywhere. Actually, it may be questionable for me to e-mail it at all. Hmm. Umm. Also, my test above works well, but may have been too simple. Upon trying a more complex test, in which the chain should move in three dimensions instead of just two, I find that the gravity prop becomes a bit unwieldy and results are less predictable. I am still testing and tweaking. If I don't hear back from Scoopey, I may convert the process to a simple figure of my own design. Then I can take you up on your generous offer for webspace. :) Thank you!
Attached Link: chain_30link.zip
I knocked together a 30 link chain figure, in case you did not get a response from Scoopy. The actual links are made out of English Bobs Morphing Torus, and he allows redistribution, see a copy of his terms of use below, so if anyone needs a chain that can be redistributed, just DL it from the link above. -------------------- Terms of use ~~~~~~~~~~~~ You can do what you like with this, with two provisos: 1) Don't pretend you made it. 2) Don't sell it without offering me a cut first :)Golly, Scott.... Sorry, I forgot to mention that the figure pictured in my example animation is the WONDERFUL HOMER SIMPSON FIGURE by ScottA.... I have a bad habit of forgetting to give credit. Umm. Sorry. I'll try to work on that.... :)
