Sat, Jan 11, 11:12 AM CST
Subject: dynamic cloth / rendering problem
ablc ( ) posted Fri, 24 January 2003 at 9:04 AM · edited Sat, 11 January 2025 at 8:20 AM
hello The shirt (clothify) seems to be nice without rendering but i got this problem when i render it in firefly or p4 mode. I try all the options without solved the problem. Any idea ? Laurent
yggdrasil ( ) posted Fri, 24 January 2003 at 11:59 AM
Did you make sure that Remove backfacing polygons was off? If so then it could be double sided polys. These can usually be fixed by attaching a noise node to the displacement channel of the material and setting a very low value (0.001). That allows Poser to separate the front and back parts of the poly and makes the renderer behave better. -- Mark
Mark
