Thu, Nov 14, 4:43 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: textures opinion
Erlik ( ) posted Fri, 24 January 2003 at 5:40 PM · edited Wed, 13 November 2024 at 9:09 AM
Which one looks better to you? This one is a photo, spruced up a bit, colours also changed.
-- erlik
Erlik ( ) posted Fri, 24 January 2003 at 5:41 PM
And this one was created from scratch in Photoshop, because photos of rust didn't look good, and Bryce's rust was useless.
-- erlik
SAMS3D ( ) posted Fri, 24 January 2003 at 5:43 PM
Definately the second one...Sharen
AgentSmith ( ) posted Fri, 24 January 2003 at 5:53 PM
2nd one.
AgentSmith ( ) posted Fri, 24 January 2003 at 6:20 PM
Btw...forgive me if you already know this. Big photo textures on smaller objects in Bryce; They can look unsatisfactory when applied normally to a mesh. I would suggest increasing the scale control on the texture. Roughly, it controls how much (or many times) your texture is replicated onto your mesh. It may not work well with that texture in particualr, but just thought I would mention it. AS
AgentSmith ( ) posted Fri, 24 January 2003 at 6:35 PM
Texture applied Sinsusoidally, scale is at zero percent on the left, fifty percent on the right.
DryFly ( ) posted Fri, 24 January 2003 at 7:15 PM
Personally I think the first one would be the better of the two for a unique chipped paint look if you lower the bump height and scale it a little differently. Unless your right up close the second one will washout to a solid brownish hue loosing most of its detail. Just my opinion though. :)
shadowdragonlord ( ) posted Fri, 24 January 2003 at 7:18 PM
Erlik, take another stab at Brycean rust, you shuld be able to produce realistic rust with just a little tweaking...
Roch222 ( ) posted Fri, 24 January 2003 at 9:03 PM
I like the texture of the 1st one. I agree with DryFly The second one will just look blah, just tweak the first one as agentsmith suggested The first one looks like patina Keep PLaying! roch222
AgentSmith ( ) posted Sat, 25 January 2003 at 4:08 AM
Actually, I know that specific texture he's using on the first one, and it looked horrible when I took the scale up. It's bluish and paint splattered on one side , flakey and rusty on the other. It's usually looks best to scale up textures that are well balanced.
Tankgirl ( ) posted Sat, 25 January 2003 at 5:19 AM
I like both...:)
Erlik ( ) posted Sat, 25 January 2003 at 6:33 AM
As the situation stands, the bars will be relatively pretty close to the camera, even closer than now. So the bumps and discolorations should be visible. Yes, I want an old, flaking paint look. I tried applying paint to the Photoshop one, but I'd need to create the flaking edges, and I have no idea how at the moment. AS, I cloned the screws and the plaque out of existence and changed the colour to a slightly greenish one, but you're right, it's too uneven to be tiled. This is World Space mapping and it looks acceptable. Only, I think I should create bump map specifically, because the grayscale version of the pic gives awful results. This is bump height somewhere around 50 and that doesn't look good. OTOH, lowering BH would just make the texture flatter. I'll also try other mappings. BTW, AS, nice model. :-)
-- erlik
AgentSmith ( ) posted Sat, 25 January 2003 at 4:17 PM
Just some replicated primitives.
