Mon, Nov 25, 11:35 PM CST
Subject: question about poses/saving poses..
unclebob ( ) posted Sat, 25 January 2003 at 7:23 PM ยท edited Tue, 22 October 2024 at 12:14 AM
I have Poser 4 and have a question about posing and saving poses. I take TaeKwonDo and am "trying" to set up P4 Michael to demonstrate the forms that we do (static and then maybe animated). My question is can I save a foot stance, then create another stance with an arm position and import the foot stance without loosing the arm position ? for example ... create a right foot forward stance and save it (called rt ft fwd stance) ... create a right arm high block and save it(called rt high block). Now I will want to do a different arm movement and "bring in" rt ft fwd stance the right foot forward stance. The reason I ask is there are several movements (high block, low block, punch .. etc) that use the same forward stance and it would be a pain to hafta position the leg/foot to the same position each time for the different movements. I guess what I am asking in non-specific terms is ... can I set up a (hand/arm) pose and import another one (foot/leg) without loosing the first (hand arm)? thanks and regards, bob I hope this is clear enough
Little_Dragon ( ) posted Sat, 25 January 2003 at 8:00 PM
Yes, you can create "partial" poses that affect specific parts of the body only, but you have to edit the pose file manually, removing the body parts you don't want affected, or use a utility like MAT Pose Edit. Alternatively, you can use regular poses and try locking the body parts you don't want affected by subsequent poses (Object menu --> Lock Actor).
mountainmaster ( ) posted Sat, 25 January 2003 at 8:05 PM
Yes, you can. When you save a pose to your library there is an option to select the subchannels you want in that pose. At least there is in Poser 5 (not sure about P4 since I don't have it).
mountainmaster ( ) posted Sat, 25 January 2003 at 8:08 PM
Oops, crosspost. But hey! Two different answers... It has to be a Poser 5 option only then.
Little_Dragon ( ) posted Sat, 25 January 2003 at 9:03 PM
No, the subset option is in Poser 4, also; I've just never thought to use it before. :)
amlaborde ( ) posted Sat, 25 January 2003 at 10:06 PM
Hmmm I think my above post may have been answered here by little dragon, thanks a bunch
unclebob ( ) posted Sun, 26 January 2003 at 9:52 AM
ahhh... too cool. Thanks a bunch mountainmaster and Little Dragon, I appreciate the help. I'll go give it a shot. thanks again, bob
unclebob ( ) posted Sun, 26 January 2003 at 11:05 AM
Oh man mountainmaster .. that little tip worked great. !!! THANKS A MILLION !!! Now I am able to get my TKD form poses done in a very much shorter time frame. I am also suprised at the small file size of the poses too, around 7-11kb each. again, thank you very much !! regards, bob also big THANK YOU as well to Little Dragon for answering my inquiry, I do appreciate it.
