I had something like this happen to me with a figure in PP a while ago. The suggestion I got was to go into the character directory and delete the .rsr file (not the .cr2 also, just the .rsr) and then load the character again and let Poser rebuild the .rsr. Sometimes those compiled .rsrs get corrupted, and rebuilding them fixes everything. Worth a try, maybe.
The .rsr's that are in the same folder as the cr2-files are the preview pictures used for P4. Deleting those won't help. It's the .rsr that is in the same folder as the obj-file (somewhere in the Geometries folder) that could get corrupt, so that's the one you should try deleting (but not the obj-file itself). Poser will rebuild the .rsr when you load the figure next time. This is true for Poser 4, I don't know about PPP.
Yes, Marianne is right... it's the .rsr in with the obj file, not the one with the cr2. Sorry for the confusion -- it's been a while since I did that. :) But I know when I tried it, it fixed the figure I was using (which showed the same kind of holes you're getting.) Hopefully it will fix Godzilla too.
