Thu, Nov 28, 4:45 AM CST
Subject: High or Low resolution maps for Victoria 3.0?
classic ( ) posted Sun, 26 January 2003 at 4:04 AM · edited Thu, 28 November 2024 at 2:01 AM
I have a 800MHZ CPU and 500MB of RAM and Poser 4.03. The Victoria 3 model will probably tax my system with its higher poly count. If I buy the High resolution maps as well, things might move at a snails pace.
Anyone here using the High Resolution Vicki 3 maps on a similar set up? I don't mind long rendering times so much, but I need to be able to manipulate the model easily - without having to resort to using the block rendering.
I remember reading a while back, that most people rarely need to be using the high resolution models. Unless its a close up of a body part, there may be no difference. Any thoughts on this?
PheonixRising ( ) posted Sun, 26 January 2003 at 4:11 AM
You should be fine. If you do head shots you'll want them. If you never zoom in tighter than the waist then you won't If you have Photoshop or an image program I would say just buy the hi-Res and scale them down to suit your needs. But save copies of the originals. And scale preserving "aspect ratio"
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
Dizzie ( ) posted Sun, 26 January 2003 at 5:08 AM
I have 850 MHZ and 512 RAM with V3 High Res. maps, on P4 & P5....it works great and not at a snails pace at all...
macmullin ( ) posted Sun, 26 January 2003 at 6:12 AM
I have a Pentium III, 800MHZ CPU, 314MB of RAM and Poser 4.03 and not having any trouble working = even with other apps open at the same time.
Staale ( ) posted Sun, 26 January 2003 at 7:08 AM
Poser generates a low rez low colour version of the map for its preview mode, so the size of the map does not affect the speed of the posing.
fretshredder ( ) posted Sun, 26 January 2003 at 12:50 PM
you could also modify the hi-res textures on your machine and save it out as a smaller file as well when needed. That is what I do. I got the hi-res textures (which are awesome BTW) and when I need lower res, I use my modifed texture... HTH
zorares ( ) posted Mon, 27 January 2003 at 9:19 PM
I'm running a Powerbook G4 800mhz with 1 Gig Ram with Poser Pro Pack and V3 with HiRez maps hums along no problem. And that's while surfing the net and other stuff in background.
http://schuetzenpowder.com/sigs.jpg
