Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 19 6:46 am)
I can't tell you where it is but I've used both PhiFactory and PhiBuilder. Stick with PhiBuilder. PhiFactory has more problems. The PHI files it creates are often not recognised by poser for example. I've never seen PhiBuilder run out of memory. What on earth are you doing with it? BTW Bushi is a member here and you can always send him an IM to ask where you can get it. The author of PhiBuilder is also a member and his nick is fur if you want to check with him about your Builder problems.
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Hello, does anybody know from where I can get the program "PhiFactory"? I had already had a look at www.bush3d.com as many tutorials suggest to look for but did not find it there. BTW: "PhiBuilder" seems not be the totally satisfying alternative because it tells you very soon that it is out of memory capacity. Many thanks in advance. Bernie
Keep cool and fight for the right of others
to have a different opinion than you have!
;- ) Bernie
