Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 24 5:52 pm)
Yes, there is a way : make a full body morph : You have to create a morph for each part that's affected by your morph. You MUST keep the same name for these morphs in each part (ex : "muscular"). Set all these morphs to 1. Delete the other morphs of each part, or set them to 0, as you wish. Create a full body morph by using the figure menu (don't forget to give it the SAME name that you used on the various parts, eg :"muscular") Go back to each part, set all your "muscular" (or whatever morph you created) to 0 Select "body" and set your body morph to 1. Et voila. I never was able to find a quicker way, but I'm not the best technician here, by far. Hope this helps. Compiler
To make it a little easier, you can cheat and do a Copy/Paste on the dials - do the left shoulder, copy the dials, then paste to the right shoulder. It isn't obvious, but the Control C/Control V will work. After you get all the parts done, (assuming you have the shoulder, the forearm, etc. to do) you can create the full body morph so you have just one dial after that to manipulate. Cheers!
If I am morphing an arm or leg (using Michael) how can I make the other arm or leg have the same morph settings without physically selecting the other body part and playing with the dials? Can you somehow make both arms morph at the same time?
