WOW...REAL close. That is REALLY nice!
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
nitpickers anonymous here ;) when a plane rolls like that the ailerons are moved in a certain way. well, i don't know the technical terms since english isn't my first language, but when a plane flies the two flaps on the wings and on the tail move :D in this case the right wing's aileron should point up, left wing's down, and possibly the tail's stabilizer moved slightly to the left. that and for a bomb to be dropped, more of water "crown" should show. aside from that, great textures, and awesome idea! drac
Thanks tjohn and draculaz. Yes draculaz the rudder should be offset to the right and the port aileron should be down and starboard aileron should be up. For now this was just a test of the textures of the water explosion. Water explosions are a tricky thing for me because they can be so different depending on just which nanasecond of the event you wish to capture. I wish I could find a high speed series of pictures that capture the whole event at say .01 second intervals.
Great explosion! just a suggestion (or opinon), the water crown at the water's surface is a little too perfect, these depend on the depth of the water, whether cold or warm water, currents, surface conditons, all effect the crown, more irregularity would be nice...
Bryce Forum Coordinator....
Is this a follow on from the explosion you were trying to create a while back? If so it is really amazing the progress you have made it looks much more realistic now. I assume you made the explosion in Rhino, you couldn't do a little tutorial could you, I'm still at a very basic level in Rhino and any tips folk can give me on using it would help me a great deal. Cheers Catlin
Hi catlin mc. Yes this is the same explosion I was working with a while back only reworked a little. The three parts on the left were modeled in Rhino while the one on the right was done in Amapi. Two of the parts done in Rhino are simple revolves and the third is basicly a torus with the bottom half sliced off. The one part on the right was an extrusion done in amapi. I have already over promised myself with tutorials, but this one should be short so I will make up one. Don't be impatient.
Hey, GG, pretty sharp image. I'm guessing the explosion in the water is a near miss from anti-aircraft fire rather than anything the plane dropped?
Digital
WasteLanD
I'm betting the prop was done with a 2d pic object and transparency map.
Attached Link: prop blur tut
Catlin mc the tut should be along in 15 hours or so. Flak you are absolutely right aa near miss I would have included a couple of air bursts too, but that would have increased render times tremendously and this is a WIP not a final so I left them out. e-artistree Thanks. nu-be That's a good idea, but I am weak on symlats. Boomer the prop blur is from a tut on Steve Sanvitos web site. http://www.geocities.com/SiliconValley/Haven/2470/proptut.html tjohn Good guess. lstrout Thanks I have always loved Snoopy and the Royal Guardsman song "Snoopy vs the Red Baron", but I am not yet up to modeling characters.HUGE thanks to you, Groin. I've been wanting to work on an image like the one I posted here, but just couldn't get the motion blur on the prop to my liking. I was using the sphere to disk method and then putting cones on their side, squashing and then distorting them to cover the rotors. But now, hehe. When I do the image that I have in mind, I'll post that also. I just blasted this one out. Need to get the swirling dust and dirt right.
Because I like to blow $%&# up.
Don't fear the night. Fear what hunts at night.
Reguarding the tutorial; How possible would it have been to make the parts you needed just in Bryce?
Freestuff | IMDB
Credits | Personal
Site
Lol...whenever I see a 3d modeling program with 4 panes, it really messes ME up. Just curious.
Freestuff | IMDB
Credits | Personal
Site
boomer- You need to rotate your blade disk through about 90 degrees. Note that you blade blurs do not line up with the rotor hub. (actually you might want to rotate the mast/hub and pitch links as a group to match the disk, this would be better visually) Now if only we could figure how to decrease the blur as you get down towards the blade root...)
