I heard its great !!!( Wings) with many export options BUT i Will need to upgrade to jaguar MAC OS 10.2 to run wings. im still on OS 10.1.5 but I will likely be upgrading soon especially if the DAZstudio Beta requires it the worlds changing fast!!!
gtrdon wrote: "Wings I tried it. Maybe its just me but my opinion Wings seems to have a very crude interface and crashes alot on my system." Wings3D is a work in progress, so if you have the latest release you might encounter some problems (crashes, etc.). I personally don't ever use the latest releases (I stay back a few), because each new release is to fix previous bugs, or impliment new tools, and sometimes when something is fixed another thing is broken in the process. Which in turn needs to be fixed in the next release. I use a very stable (no crashes) release with all the working plugins, and I have no problems on my system. But my system also includes a multiple removable drive system, so I am able to test the new releases on one drive while actually creating models for Poser on another drive. As far as you see it as having a "crude" interface: Do you mean simplistic, or in your opinion, just plain ugly? Some of us subscribe to K.I.S.S., and in my opinion, it is an adequte interface for it's purpose.
Its not intuitive.
I had a heck of a time trying to get a Poser head morph
into it to try to alter the mesh. I have been trying several free, trial and shareware programs and all of them within a few minutes I was able to figure out how
to do this. (Though with mostly dissapointing results).
I use RDS 5.5 and it is antiquated, slow and clumsy but it works.
In the process of trying to learn how to navigate the Wings interface to do what I wanted, the program crashed on me several times.
The help screen didn't have much info. So without spending
alot of time taking a tutorial I gave up.
Maybe if I have a few hours to spend I will download a less
buggy version and try to find a tutorial. But I'd rather be playing and learning to use my Poser 5 right now than to deal with the frustration of tryinng to get it to do what I want.
PS: If someone would be willing to give me some hints on how to import a poser .obj , resize, and get into the edit mode I might be able to figure out the rest..
Attached Link: http://www.artofillusion.org
I always found Wingz kind of limited. Take a look at Art of Illusion. Procedural textures, GI, animation, bones, obj import/export, runs virtually anywhere and much more. Very impressive and of course, free."Democracy is a pathetic belief in the collective wisdom of individual ignorance." - H. L. Mencken
Thanks for the tip Imkenzie!
Art of Illusion is a impressive program. And easy to use.I needed no manual to navigate around.How do they do all that in less than 2 meg?
I did have a little problem though trying to create morph targets. First I scaled the object up 10 times so I could see it then I scaled it back down by 10 after editing. I did not move the location of the object in the program. But when I imported it back into Poser as a MT it caused the model act as if there had been a position shift in the MT. This doesn't happen in Ray Dream unless I move the object meant to be used as a MT.
I had better luck using it than Wings.
Yes but the poser object is so small that at zoom max it is still too small to work with. So the next thing left is to scale it up. I have found this out on just about any of these low cost or free CG programs. For some reason Poser seems to generate very small objects. Maybe one of CG Wiz guys knows why.
gtrdon, yes, AOI is a very impressive program and faster than I would have thought for being implemented in Java. As for the sizing thing, I've used it mainly for creating models rather than modifying them. The zoom works fine with Poser models from what I've tried. Try using the camera move function then holding down the shift and dragging to zoom. Your window has to be perspective mode for this to work. You casn combine this with the preset window zoom levels to get a pretty good zoom. You may have to play with the camera settings or position to get a really huze zoom in but I haven't really played with it that much.
Attached Link: Free Stuff!
More free stuff from William Vaughn and Company!
