Thu, Feb 20, 7:23 AM CST
Forum Moderators: RedPhantom
Subject: Simple question
bonestructure ( ) posted Thu, 04 May 2000 at 9:57 PM ยท edited Wed, 19 February 2025 at 10:26 AM
Okay, remember I'm still a poser newbie. When I design clothes on a template, how do I make sure that the front and back match up right, like shoulder straps, etc?
Talent is God's gift to you. Using it is your gift to God.
Jaager ( ) posted Thu, 04 May 2000 at 10:49 PM
One method: Open the model in Painter 3D, carefully make variously colored lines that cross the seams. This will show you where to match up the lines on the template. When you get near the seams, place the color one dot at a time, rather than painting continuous lines. Do it the other way once and you will see why. This works best if ypur paint program supports layers.
bonestructure ( ) posted Thu, 04 May 2000 at 11:10 PM
well, I have photoshop and PSP and painter 3d, so that's not a problem
bonestructure ( ) posted Fri, 05 May 2000 at 3:28 AM
cool
Jaager ( ) posted Fri, 05 May 2000 at 11:11 AM
The mesh lines are not what I was discussing. I prefer P6 to do textures, but on a mesh that is split front-back, it is difficult to do tan lines,etc. By drawing lines across the seam in different colors, it makes it easier to make the match, especially if this guide is a partially transparent layer, to be turned off for the final texture. To repeat advice that was given to me here: Take your model into UVMapper, save it as a single group with a different name and "aquire" the model in Painter 3D. If you want to live in P3D you will not need the guide lines, but the layer function is not nearly so robust as it is in P6, or as I understand it PSP or PS.
Oliver S ( ) posted Fri, 05 May 2000 at 4:07 PM
A more accurate way to line up items back to front is to use the bezier paths in Photoshop. The grid lines in UVMapper generated template have a width, and some high resolutions choosing where the middle of the grid line is, can make or break the joint. It is fiddly getting the paths to line up, but when you have them completed you have a series of accurate lines in the paths palette. Stroke the paths and you will have beautifully flowing lines for edges of clothes, seams etc that you can use over and over again - no freehand wobbles.
Oliver S ( ) posted Fri, 05 May 2000 at 4:11 PM
And in Photoshop it is best to 'multiply' the texture layer on top of the background template - you get a better feel for the colour depth when working in the texture than using slight transparency.
