Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 11:25 am)
Download the latest version of the figure and reinstall it. Questor has the Mark 4 Terminator on his site:
A few tips: turn off Inverse Kinematics after loading the figure, and select Edit Menu --> Restore --> Figure, to straighten out the legs.
By the way, I do hope you have a powerful system. Fast processor, lots of RAM? I haven't checked the latest version, but an earlier mesh had almost three times as many polygons as Victoria 3. This, plus the fact that the figure is very complex, with many moving parts, can bog down even a high-powered machine.
That's more than enough to use the figure; I doubt you'll have the smoothest performance (I'm on an Athlon XP 2000+ with 512MB, and it's still a bit choppy), but it'll run. I was even able to use it on a Pentium 3-800 with 128MB, although I wasn't going to use much else at the same time. I had the same problem with the older version (the one with the weapon) in Pro Pack also, but I installed the new one and it works, even in Poser 5.
Hi everybody... well, my problem is this... once I get a T-800 Terminator Model, it's a James Torbor model, but now, I installed Poser 5 in my computer and when I open T-800 model file only the weapon is showed. This problem happens with Poser 4 Pro Pack too. What I have to do for open my file in Poser 5??? Thanks!!!
