Sun, Feb 2, 2:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: Any tutorials for P5 setup room?
ramble1035 ( ) posted Mon, 03 February 2003 at 12:44 PM ยท edited Sun, 02 February 2025 at 2:47 PM
I'm in need of some pointers: tutorials, threads, tips, manuals, books, ... :) I tried to do a simple starter project - stack up a bunch of cylinders and turn them into something bendable. The idea was to eventually make something like a rope or a tail. Unfortunately, I don't get too far. I need some really basic stuff, I think - like how to create a figure with props. (I've seen the "goldy" tutorial, but that starts with a completed figure already loaded in.) Anyway, suggestions would be appreciated.
dan whiteside ( ) posted Mon, 03 February 2003 at 1:13 PM
Attached Link: http://arcana.daz3d.com/tutorials/propack.html
There's some for the P4 setup room which I presume is the same for P5. Christopher Orth and Craig Burton have tuts at the link above (as well as some other PP stuff) and I have one that takes a different approach here: http://www.bryceworks.com/tutorial/mushbone/mushbone.html HTH; Dan
EsnRedshirt ( ) posted Mon, 03 February 2003 at 2:06 PM
  • takes notes - I was about to start writing a P5 setup room tutorial. I guess I'll add "how to make props from primitives" to it. Hmm, I should make the whole figure in Poser 5 itself as an example.
ramble1035 ( ) posted Mon, 03 February 2003 at 2:27 PM
Dan - thanks for the pointers, but "Qarbon" (which the basic - and apparently useful - tutorials are written in) fails miserably for me on all my possible browser combos. Which means -- EsnRedshirt - write faster! :)
EsnRedshirt ( ) posted Mon, 03 February 2003 at 3:01 PM
Unfortunately, importing figures which you've made in a seperate 3d application is the best way to do it- although you can, in theory, use magnets on primitives to morph them into figures, you'll never get the level of detail you can reach with a 3d modelling program.
Tomsde ( ) posted Mon, 03 February 2003 at 3:22 PM
The Poser 5 Setup Room is the same as the Poser 4 Pro Pack set up room, so any tutorials for PP4 would work. Curious Labs used to have a tutorial on making a simple laptop prop, but I'm not sure if that is offered anymore; I was going to check for you but I can't get into the Curious Labs website right now. Poser 4 Pro Pack FX and Design has a whole chapter on the set up room, if you have access to that book that might be a help. Creating models with Poser's limited selection of primitives would indeed be a challenge. I've seen free primitive collections to augment Poser's on the web; if you want to model something with primitives it might help to have a larger selection. I think that what you end up doing when you get the hang of it more would be to import models from other applications to convert to poseable figures.
hauksdottir ( ) posted Mon, 03 February 2003 at 9:38 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1030260
Dr Geep's office chair made entirely with the basic Poser primitives is pretty amazing. Collecting all the other primitives out there can only add to to what we can do! Carolly
