Mon, Feb 3, 6:39 PM CST
Subject: Circular camera path
gddesign ( ) posted Tue, 04 February 2003 at 12:51 AM ยท edited Mon, 03 February 2025 at 2:26 PM
I'm trying to render a bunch of images going round a scene at controlled intervals - does that make sense? Using Poser4. If I make a movie of a walking action for example, I can get a series of images to save, but the camera's not moving. If it does move, it's only along the camera path polyline. I want the camera to go round the scene (like it does in the orbiting preview) in a circular path taking shots towards the center at controlled intervals of maybe 10 degrees at a time. Anybody got a clue? Maybe use a script to program this?
Little_Dragon ( ) posted Tue, 04 February 2003 at 2:11 AM
Planning to do a Bullet-Time effect? 1. Load a cylinder prop from the library (any prop will do, actually, but I like the cylinder because I'm about to make a "hub" analogy), and place it at the center of the scene. 2. Select the camera; aim it at the cylinder, either manually or with the "Point At" feature. 3. Parent the camera to the cylinder. Now you've effectively got a wheel, with the camera on the rim and the cylinder as the hub. 4. Make the cylinder invisible so it doesn't ruin the scene. 5. Rotate the cylinder along its y-axis, and the camera will follow.
gddesign ( ) posted Tue, 04 February 2003 at 6:55 AM
Awright - thank you so much!!
geep ( ) posted Tue, 04 February 2003 at 10:24 AM
Or you could just animate (change) the "yOrbit" for the camera. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
jerr3d ( ) posted Tue, 04 February 2003 at 11:34 AM
sounds like a cool animation, hope you post it when it is finished!
gddesign ( ) posted Tue, 04 February 2003 at 4:37 PM
Yes, animating the camera is what's required, but what I'm trying to figure out is how to automate that, 'cos I've got a whole lot of these suckers to do. It's just too tedious to reset the camera's orbit manually for every rendering.
geep ( ) posted Tue, 04 February 2003 at 5:01 PM
If you want the camera to rotate 360 degrees,
just set:
Frame#1 camera yRotate to 0 degrees
Frame#(last) camera yRotate to 359 degrees
... and Poser will fill in all the inbetween frames correctly.
Want it to go the other direction?
Just set last frame to yRotate to (minus) -359 degrees.
If you want it to stop anywhere, just use the graph editor and set the spline to "constant."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
gddesign ( ) posted Tue, 04 February 2003 at 5:24 PM
dr geep, you are a genius.
geep ( ) posted Tue, 04 February 2003 at 5:26 PM
Maybe a tut on cameras? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
gddesign ( ) posted Tue, 04 February 2003 at 5:48 PM
Any tut is a good tut.
