Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
The nature of the Second Skin MATs are to change material zones by adding information. The MATs have limited usability when you then want to take information away. With the "MakeShort" MATs I had no way of anticipating what V3 texture you would be using as a base, therefore no way to tell the MAT to restore that texture when you want to make your pants into shorts or long sleeve tops into tees. The MATs that remove Second Skin in any way shold restore the appropriate material zone to the V3 default object colors. At that point, you will need to use the Materials editor to restore the V3 texture you are using to the untextured body part. I hope that helps! :) Lisa
That's looking pretty good to me :) I'm picky - I've probably found the 1 "flaw" in the whole set (though it does seem to propogate across the other textures in the set). As for urgency - none here, sit back, make sure you're happy with the update and I'll grab it off the site when everyone else does. The turtle will just have to eat greens for a while . Cheers, Cliff Bowman PS gripes aside, some nice designs :)
Anytime Lisa - please ignore Ryan if he gets in touch asking if there's any issues with the seams! He'll be duplicating effort I suspect. I hear Steve Cox's "UV Mapper Pro" is supposed to work in combination with most bitmap editors to give a near - realtime view of a texture in place on a model. I've not tried it myself but it sounds like a handy way of (quickly, easily) checking out texture painting (it uses OpenGL so should be a LOT better than Poser previews). Cheers, Cliff
Sometimes the clothing textures show up, and other times I just end up with a nude V3 figure with a few white zones (see attachment). The attached picture was made right after applying the MATs for the "V3 Top MakeSleaveShort" and "V3 Pants MakeShort."
Anyone know what is going on?
I am running Poser 4.0.3 and Victoria 3.0 with the latest service release applied.
