Wed, Dec 4, 2:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 12:42 pm)
Subject: Hands are becoming deformed
Sickethunder ( ) posted Fri, 07 February 2003 at 2:06 PM ยท edited Wed, 24 July 2024 at 1:42 PM
Here's my issue...I'm trying to make a character holding one long stick with both hands (see other topic below) I figured that i can make them all move together if i make a chain, and use the IK controls... but whenever I go to make a chain, i connect the stick to parent right hand, and it works fine then i connect left hand to the stick, and the left hand/arm becomes completely deformed...i'm not quite sur what it's doing, but it's definitely making the arm "fubar" how do i avoid this?
Sickethunder ( ) posted Fri, 07 February 2003 at 2:20 PM
here's an example step 1...select left hand
step 2...select stick as parent for left hand
Sickethunder ( ) posted Fri, 07 February 2003 at 2:21 PM
result...a really messed up left hand how do i fix it?
mateo_sancarlos ( ) posted Fri, 07 February 2003 at 2:29 PM
If the stick is scaled and rotated prior to parenting, it will do something similar to the hand when you parent it.
raven ( ) posted Fri, 07 February 2003 at 5:39 PM
Turn on IK for the arms, then parent each hand to the stick, and then move the stick. The hands should then follow.
