hehe go figure. what max was doing to me was adding in a random poly across one of the serfaces, course the export plugin for obj's at that time was a 3rd party plugin, i'd end up setting the one little random poly to its own group then trash it (cause it was a extra) but thats not always the case and you'd end up with a hole.
looking at the picture above, I think the pants ARE affected by export setting problems I had. It looks lumpier than the top. Lumpy was a symptom of the problem I was having with an earlier version of the top. I just hope I saved a version of the mesh not affected so I can fix it. Well if I am going to do that I may as well package the top and pants together, is that ok with everyone? It makes a larger download putting them together, but if you guys don't mind waiting a little longer... :)
A really easy way to assign it to the poly group, sense its on the outer edge, turn on the group editor, then click the button for 'Wire Frame' display mode (where its the seethrew wire frame) when you select the group there on the end of the shoulder where that randome little guy's hiding, it will asign both inner, outer, and back polys into the group ;) speeds things up a bit when little problems like that accure.
I just yesterday found out that there must be something fishy about that HABware plugin. I normally use that as well, but after I saw an answer in here, I tried to export my object with the 3ds option instead. Now I HAD a version I'd made with the HABware ojb and it had LOADS of inverted polygons, colinear stuff and more unwanted things. After having fixed all I COULD fix in UVMapper, there was STILL black polys in my mesh. Sooo I tried once more, exporting the item as 3ds, importing that to Poser, exporting from Poser as obj and looking at it in UVMapper.. BEHOLD: NO messy stuff AT ALL! so I know what I'm going to do in the future. And that does NOT include using the HABware plugin!
Oh Taura Noxx... I completely forgo t to say: What a great looking top! I look foreward to it :o)
thats one thing i like about rhino. the figures are aprox. 1 grid high, so scaling objects up and down to get them the aproprate size is pretty easy :) When i model clothing for the figures i use the same method, so i mark one grid to scale the figure by then scale the figure to the edge of the full grid size, making it big enough to model things to, then scale the new model back down in the reverse and it keeps everything in perfect scale :) welp enough for me im off to bed :) hope ya get everything worked out :)
