Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 12:22 am)
Dizzie, the "start in" setting in properties for your Poser shortcut, "sets" the working directory. A quick and dirty expnation of why this has anything to do with Poser remembering your settins is; when the "start in" field in the shortcut's properties is left blank, the working directory is not "set" so the system does not know where to tell Poser to look for your saved preferences settings, which is why Poser will not "remember" your screen configuration when you start it up. when you say "correct the shortcut" never works for you, what exactly do you mean? What OS are you using and what exactly are you doing to "correct the shortcut"?
WOW Illusions! I can't thank you enough! You are the 1st person (that I've noticed) who said to correct the "start in" path...all I've ever heared is correct the path in the shortcut....well, it's never been wrong (the path to the poser.exe).....so that has never worked....nor made any sense to me....but when I added the path to the "start in" just like you said and then opened Poser, everything was exactly where I wanted it....I have fretted with this for almost 2 years.....LOLOLOL Duhhh, I coulda had a V-8! Thank you for being specific!
Illusions, thank you for this tip. However, I found the 'start in' which was blank, so I would appreciate if you could tell me what I should type in this field, the same as in the 'target' or something else, or do you delete the 'target' and just put what is there in the 'start in' instead. Thank you, Jan
This is a minor annoyance that I would love to fix. Each time I launch Poser I have to rearrange the elements on the interface. Thankfully Poser does save most of my user preferences, but things like the position of my work window, UI dots, and the Document Display style always need to be positioned.
Does anyone know of a fix for this? Of course, I did try: Edit > Poser Preferences > Set preferred state.
