Did you activate the light cones for the spots that you want to see the light shafts eminating from? If not, you will not see any shafts of light no matter how much fog is in the scene. Lights in Carrara do not react to fog the way lights in the real world do. Light cones in Carrara are not volumetric, they are post render effects. Activate the light cones in order to see the shafts. It's in the effects tray for each individual light. To get your desired effect, try it with and without the 3D shadow option turned on.
![file_45650.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_45650.jpg)
This is my first attempt to do volumetric lighting. I've added some light fog to the street scene, and I want shafts of sunlight to be coming down. I built a box [four deep sides and a bottom with holes] and installed spotlights shining down in it. But I can't see light shafts. The box is just above the camera frame. Can't bring it down any further. Is there not enough fog? Or, is this not the way to go? Gels, perhaps? I've yet to use gels either. What might the proper gel look like?
