Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 12 2:36 am)
Remember, kids! Napalm is Nature's Toothpaste!
This is a 1 minute or less quick sketch here at work on paint to show the idea ( laugh )
A small bot that hovers about, his lower round body would be partially see thru, filled with electricity and lightning.
The body above would melt from transparent to a kind of Shiny metal segmented section on the neck (think of the Xmen series with that guy that turns all metal) That kind of segments. His antenna would be segmented also, and the antenna balls would be small see thru sections full of electricty as well. Eyes are standard round robot eyes, with eye covers that blink. :) Also..his neck can grow longer or shrink as he needs, each segment withdrawing into the larger one below itself.
Attached Link: http://www.pumpkintechnologies.com/gimp/gimples.htm
![file_45945.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_45945.jpg)
What would you say to a set of 3-4 robots in a similar style to the one above, but each one different? BTW, the torso pieces are all separate body parts, and use ERC so that you need only bend/rotate/side-side the top torso portion, and all the adomen "plates" rotate/etc a proportionate amount...Remember, kids! Napalm is Nature's Toothpaste!
