It may not be all that difficult. Select both trees and go into solo mode now select the one tree that you want un-AA and do a render mask. Only those parts that can be seen will be white. It's what I did because the Aslan (in Refueling on Planet X) was in front of the tentacles. I took them both into solo mode then unselected the Aslan and rendered the mask, where his legs were in front of the tentacles showed as black. One note here, to do a object mask with metaballs that are grouped. You can't select the groups, the mask won't turn out right, you have to select just the metaballs.
Does anyone know whether it's possible to turn off antialiasing on tree-lab trees? The normal method for other objects - Shift+Ctrl and click the tickmark in the attributes box - doesn't work. (Trees have no attributes box anyway, and if you do this from the tree's edit box it has no effect.) Many thanks
