Fri, Nov 22, 9:25 PM CST
Subject: i have problem when i import a 3d max model to poser!!!!!!!!!!!!!!!!!!!!!!!!!!!
Benettor ( ) posted Sat, 15 February 2003 at 1:13 PM · edited Fri, 22 November 2024 at 5:18 PM
i have problem when i import a 3d max model to poser the model after that is sooo smooth :(((((( look out the image what i must do with this ? can i take the same result from max to poser? plz help me thnks anyway:
  • Benettor - Photographer - My Art
PapaBlueMarlin ( ) posted Sat, 15 February 2003 at 1:27 PM
what file format did you export it as? an obj or 3ds?
SamTherapy ( ) posted Sat, 15 February 2003 at 1:46 PM
Sounds like the polygon smoothing thang which Poser does so well. You need to split the vertices (if my failing ol' brain is correct) then you'll have nice sharp edges. The good doctor (Dr Geep) has a tute all about dis kinda t'ing. Search for "geep" in this very forum. For the life of me, I cannae remember which of his tutes it is, and I assure you I have just been looking.
chanson ( ) posted Sat, 15 February 2003 at 1:53 PM
The above Geep tutorial is good. Two ways I know of to do this. the easiest is to take your obj file into uvmapper and do a "split vertices" on it there. The other is more complicated, but if you slightly chamfer your edges in 3dsmax, you should accomplish the same thing. I usually approach it with uvmapper, myself.
Valandar ( ) posted Sat, 15 February 2003 at 2:20 PM
If this is Poser 5, turn "Polygon Smoothing" off in the Render Options window.
Remember, kids! Napalm is Nature's Toothpaste!
Benettor ( ) posted Sat, 15 February 2003 at 3:27 PM
thnks :))))) you are my aggels i try this in my models :)
odeathoflife ( ) posted Sat, 15 February 2003 at 5:22 PM
Don't cross post, I answered your questions in the other forum and I see now it was a waste of my time.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Maz ( ) posted Sun, 16 February 2003 at 4:15 PM
Ditto Maz
Phantast ( ) posted Mon, 17 February 2003 at 5:09 AM
You also have a problem with your keyboard. Some keys seem to stickkkkkkkkkkkkkkkkkkkkkkkkk
