grim, can you post a picture of how you sections the dress? Did you include buttock and/or thigh sections? A wireframe render might help as well. Oh, one quick one that gets me occationally... AZre you sure you have the rButtock/lButtock and rThigh/lThigh sections on the correct side of the dress? mike
Thanks. The r/lButtock is a good hint, sometimes I get confused but in this case the part is ok
The problem is: with r/lButtock the Dress looks like form behind like this (see Photo). Other people like Jim Burton Glamorous Vicki Set for Victoria 3.0 dont use r/lButtock in the groups they only use Hip (how to say in English) for the down part of the Dress. If I do it the same the Dress will not conform (in the down part). See Photo
Thanks to all
Grim
Ok... (one question thou, why there were only props(.pz2) and not a conforming dres(.cr2) on the mail...?) Aparently the mesh was originaly exported from a .3ds and then imported into poser(am I wrong?), the polycount is a little extrem but that's ok if you have enough machine power(specialy since they are triangles and not quadrangles)... (btw,what is you native languaje, is it English, o es el Espal al igual que yo?) Ascii
Talk in the Forum? why not 1. I had problems to send the email it was to large, sorry. 2. Yes it comes form 3ds, the polycount is so high because the shape is fine with simcloth. 3. I have no problems with my machine power, do you have? (AMD Athlon 700, 650 MB RAM) 4. To use quadrangles not triangles its new for me, why it is better? 5. My native lang. is German. And you ? Grim
Okidoki, check your mail(1.4 MB)... (btw, quadranglws means 4 point polis, like a square, your mesh are made of triangles and the extra lines makes it larger, plus there's no need to make a two sided piece of cloth(that would cut the size at half), just make the edges a litle rounded to simulate thickness and cover the "I can look inside you dress from above" areas)... Regards... Ascii
Maybe somebody will share/ join my work and can help me. I will send the .3ds, .obj or what ever to you.
Even for useful tips I will be happy. For the Dress see attached JPG.
The Problem is if I move the legs, the Dress will not follow.
Greetings
Grim
