Fri, Jan 24, 8:36 PM CST
Subject: Horizontal black lines in renders?
poser ( ) posted Sun, 16 February 2003 at 1:24 PM ยท edited Thu, 09 January 2025 at 7:59 PM
Hi all, I'm trying to render a scene with a simple wall prop/texture in Poser 5 using the Poser 4 engine. The wall comes out with many thin black lines running across it. Other elements in the scene are fine. Any ideas? Thanks.
Little_Dragon ( ) posted Sun, 16 February 2003 at 2:30 PM
It's probably P5's sensitivity to double-sided polygons. If you're familiar with the Material Room, plug the texture node into the Displacement channel, and set the displacement strength to a very low value (0.0001).
poser ( ) posted Sun, 16 February 2003 at 3:19 PM
Thanks for the advice, little dragon. However, I tried it using various displacement strengths (.0001, .1, 1, -1, etc.) and it didn't seem to help. I noticed that the horizontal bars also occur when using the Firefly engine. All the other elements in the scene render fine, and I have checked all the render settings (anti-aliasing, etc.).
compiler ( ) posted Sun, 16 February 2003 at 3:39 PM
Try to change your light properties "min shadow bias" to something between 1 to 3. I'm not sure this will work, though : just my 2 euros advice.
poser ( ) posted Sun, 16 February 2003 at 4:52 PM
Thanks I'll try it but since the problem occurs only on the wall I don't think I should change any global settings that will affect the whole picture.
cYn ( ) posted Sun, 16 February 2003 at 5:31 PM
Are you checking the boxes for 'use displacement maps'and 'remove back facing polygons'in the render options screen?
poser ( ) posted Mon, 17 February 2003 at 11:26 AM
I tried the displacement maps as outlined by little dragon above. I didn't see a "remove back facing polygons" option for the Poser 4 engine, but yes, when I tried the Firefly engine, that option was already checked and the lines were still there. I seem to remember these lines being an issue a while back but I can't find the thread.
